Community
cancel
Showing results for
Search instead for
Did you mean:
hdong5
Updating image using Flash Tool Lite failed.
Jump to solution
Dear Sir,
I am using Macbook Pro and trying to update the image using mini board and Flash Tool Lite.
It is fail to see a Edison device, but I can see the console as: /sbin/init: error while loading shared libraries: libkmod.so.2: cannot open shared object file: No such file or directory
The Flash Tool is fail to connect edison.
Anyone can solve this problem?
Many thanks
User
Pablo_M_Intel
Hi haodong,
Could you please share an image of the error that you are getting? Also, did you follow a guide to install and run the Flash Tool Lite? If not, I would suggest you to check this link https://software.intel.com/en-us/installing-firmware-with-flash-tool-mac https://software.intel.com/en-us/installing-firmware-with-flash-tool-mac.
If that doesn't work you can try with this alternative method, .
PabloM_Intel
Pablo_M_Intel
Hi haodong,
PabloM_Intel
hdong5
Thanks PabloM, I solved the problem with /docs/DOC-25154 How to Run the Flashall Script.
: D
