Intel® Makers
9881 Discussions
Updating the Capsule image from the UEFI shell failed with divide error exception
Community Manager
Hello All,
I was trying to update Capsule image from the Uefi shell according to the document "Intel® Quark™ SoC X1000 Board Support Package (BSP) Build and Software User Guide" section 10.2.
It got succeeded in Galileo 2 reference board but failed on my custom board with below error.
Evaluate DXE DEPEX for FFS(93B80004-9FB3-11D4-9A3A-0090273FC14D)
All UEFI Services Available = FALSE
RESULT = FALSE
Evaluate DXE DEPEX for FFS(E2775B47-D453-4EE3-ADA7-391A1B05AC17)
RESULT = FALSE
Evaluate DXE DEPEX for FFS(BDFE430E-8F2A-4DB0-9991-6F856594777E)
RESULT = FALSE
Evaluate DXE DEPEX for FFS(4ACA697E-F883-446F-98F7-096416FFFFFF)
RESULT = FALSE
Evaluate DXE DEPEX for FFS(240612B7-A063-11D4-9A3A-0090273FC14D)
RESULT = FALSE
Evaluate DXE DEPEX for FFS(2D2E62CF-9ECF-43B7-8219-94E7FC713DFE)
RESULT = FALSE
Evaluate DXE DEPEX for FFS(2D2E6!!!! IA32 Exception Type - 00(# DE - Divide Error) CPU Apic ID - 00000000 !!!!
EIP - 3F8DA64C, CS - 00000010, EFLAGS - 00000246
EAX - 9000B000, ECX - 9000B000, EDX - 00000010, EBX - 00000042
ESP - 3F8C6DDC, EBP - 3F8C6EEC, ESI - 00000022, EDI - 3F8C6E0C
DS - 00000008, ES - 00000008, FS - 00000008, GS - 00000008, SS - 00000008
CR0 - 00000013, CR2 - 00000000, CR3 - 00000000, CR4 - 00000000
DR0 - 00000000, DR1 - 00000000, DR2 - 00000000, DR3 - 00000000
DR6 - FFFF0FF0, DR7 - 00000400
GDTR - 3F825E90 00000047, IDTR - 3F558010 000007FF
LDTR - 00000000, TR - 00000000
FXSAVE_STATE - 3F8C6B20
!!!! Find PE image c:\varalaxmi\Build\capsule\DEBUG_VS2012x86\IA32\MdeModulePkg\Core\Dxe\DxeMain\DEBUG\DxeCore.pdb (ImageBase=3F8C7000, EntryPoint=3F8C7260) !!!!
Attached the full log below.
Varalaxmi
Community Manager
Hi Varalaxmi,
Thank you for contacting us. I understand from your case that the Capsule image file you programmed on the Galileo, doesn't work on you custom board, is this correct? We reviewed the file you attached, but, unfortunately, it doesn't provide us any clues of what might be wrong with your setup. Could you explain in more detail how you build this file, which steps you followed from the BSP and any configuration specific to your custom board? Also, are there major hardware differences on your design in comparison to the Galileo? The more information we have, the easier it'll be for us to help you.
We'll be waiting for your response.
-Sergio A
Community Manager
Hi Varalaxmi,
Do you still need assistance with this thread? If you still do, please respond with the information we requested above.
-Sergio A
Community Manager
Hi Sergio,
Sorry for the late reply.Yes your analysis is correct.
Build procedure:
build -a IA32 -t VS2012x86 -p QuarkPlatformPkg\Quark.dsc -D CAPSULE_ENABLE
Update procedure:
1.upgrade the board latest quark.fd
2.copied CapsuleApp.efi and QUARKFIRMWAREUPDATECAPSULEFMPPKCS7.Cap to drive
3.executed the below command
CapsuleApp.efi QUARKFIRMWAREUPDATECAPSULEFMPPKCS7.Cap
Hardware changes:
these days i did investigation on this issue.I found some clue that we did not connected RTC on our Quark but Capsule update utility is using these RTC on persistant capsule writes to do S3.
in this file QuarkSocPkg/QuarkNorthCluster/Library/ResetSystemLib/ResetSystemLib.c
in function
EnterS3WithImmediateWake()
//Pograming RTC alarm for immediate WAKE
in this file we are using that RTC wake event
"QuarkSocPkg/QuarkNorthCluster/Library/IntelQNCLib/IntelQNCLib.c
in function
QNCCheckS3AndClearState()
// Detect the actual WAKE event(it got failed and return false)
If above function returns false than it will skip the "boot mode flash update" which is basic requirement to upgrade the flash with new image and failed to update the flash with the new image.
The above is the major change i found and remaining all are same.
Please help me to analyze this issue.i got struck at this issue from many days.
Varalaxmi
Community Manager
Hi Varalaxmi,
Thank you for providing the information we requested. We'll do some research before posting our suggestion. We'll reply back as soon as we have an update.
-Sergio A
Community Manager
Hi Varalaxmi,
Thank you for your patience. We now have some updates for this case. First, we want to clarify comment we found to be somewhat misleading:" I found some clue that we did not connected RTC on our Quark, but Capsule update utility is using these RTC on persistent capsule writes to do S3." Our guess is that you found S3 using the RTC code and your board is not using RTC, so it may be causing this problem. Would you please clarify?
Also, from your log attached above it seems that it's very different from a non modified BSP log.
Could you use an unmodified UEFI debug version image and update the Capsule on both your custom board and on the Galileo Gen 2? Capture the logs on both boards and attach them to the case. That way it'll be easier to compare the logs and hopefully find a clue as to what the problem may be.
-Sergio A
Community Manager
Hi Varalaxmi,
-Sergio A
Community Manager
Hello Sergio,
I found some work around and it is working fine now.Thanks for your support.
Varalaxmi
Community Manager
Hi Varalaxmi,
Thanks for letting us know you managed to solve this issue. Feel free to contact us again if help is needed, we'd be happy to assist you.
-Sergio A
