Intel® Makers
9881 Discussions
Upgrading spicy with anaconda
AMont11
Hi all,
I am trying to update my spicy module in anaconda(for python2.7) that I installed on my edison but the following error occurs :
Downloading/unpacking scipy from https://pypi.python.org/packages/source/s/scipy/scipy-0.17.0.tar.gz# md5=5ff2971e1ce90e762c59d2cd84837224 https://pypi.python.org/packages/source/s/scipy/scipy-0.17.0.tar.gz# md5=5ff2971e1ce90e762c59d2cd84837224
Downloading scipy-0.17.0.tar.gz (12.4MB): 12.4MB downloaded
Running setup.py (path:/tmp/pip_build_root/scipy/setup.py) egg_info for package scipy
warning: no previously-included files matching '*_subr_*.f' found under directory 'scipy/linalg/src/id_dist/src'
no previously-included directories found matching 'benchmarks/env'
no previously-included directories found matching 'benchmarks/results'
no previously-included directories found matching 'benchmarks/html'
no previously-included directories found matching 'benchmarks/scipy'
no previously-included directories found matching 'scipy/special/tests/data/boost'
no previously-included directories found matching 'scipy/special/tests/data/gsl'
no previously-included directories found matching 'doc/build'
no previously-included directories found matching 'doc/source/generated'
no previously-included directories found matching '*/__pycache__'
warning: no previously-included files matching '*~' found anywhere in distribution
warning: no previously-included files matching '*.bak' found anywhere in distribution
warning: no previously-included files matching '*.swp' found anywhere in distribution
warning: no previously-included files matching '*.pyo' found anywhere in distribution
Installing collected packages: scipy
Found existing installation: scipy 0.14.0
Uninstalling scipy:
Successfully uninstalled scipy
Running setup.py install for scipy
lapack_opt_info:
openblas_lapack_info:
libraries openblas not found in ['/home/root/anaconda/lib']
NOT AVAILABLE
lapack_mkl_info:
mkl_info:
libraries mkl,vml,guide not found in ['/home/root/anaconda/lib']
NOT AVAILABLE
NOT AVAILABLE
atlas_threads_info:
Setting PTATLAS=ATLAS
libraries ptf77blas,ptcblas,atlas not found in /home/root/anaconda/lib
libraries lapack_atlas not found in /home/root/anaconda/lib
numpy.distutils.system_info.atlas_threads_info
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /home/root/anaconda/lib
numpy.distutils.system_info.atlas_info
NOT AVAILABLE
/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/system_info.py:1432: UserWarning:
Atlas (http://math-atlas.sourceforge.net/ http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
warnings.warn(AtlasNotFoundError.__doc__)
lapack_info:
libraries lapack not found in ['/home/root/anaconda/lib']
NOT AVAILABLE
/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/system_info.py:1443: UserWarning:
Lapack (http://www.netlib.org/lapack/ http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
warnings.warn(LapackNotFoundError.__doc__)
lapack_src_info:
NOT AVAILABLE
/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/system_info.py:1446: UserWarning:
Lapack (http://www.netlib.org/lapack/ http://www.netlib.org/lapack/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
warnings.warn(LapackSrcNotFoundError.__doc__)
NOT AVAILABLE
Running from scipy source directory.
Traceback (most recent call last):
File "", line 1, in
File "/tmp/pip_build_root/scipy/setup.py", line 265, in
setup_package()
File "/tmp/pip_build_root/scipy/setup.py", line 262, in setup_package
setup(**metadata)
File "/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/core.py", line 135, in setup
config = configuration()
File "/tmp/pip_build_root/scipy/setup.py", line 182, in configuration
config.add_subpackage('scipy')
File "/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 966, in add_subpackage
caller_level = 2)
File "/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 935, in get_subpackage
caller_level = caller_level + 1)
File "/home/root/anaconda/lib/python2.7/site-packages/numpy/distutils/misc_util.py", line 872, in _get_configuration_from_setup_py
config = setup_module.configuration(*args)
File "scipy/setup.py", line 15, in configuration
config.add_subpackage('linalg')
caller_level = 2)
File "scipy/linalg/setup.py", line 20, in configuration
raise NotFoundError('no lapack/blas resources found')
numpy.distutils.system_info.NotFoundError: no lapack/blas resources found
Complete output from command /home/root/anaconda/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_root/scipy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-qr1j6d-record/install-record.txt --single-version-externally-managed --compile:
lapack_opt_info:
openb...
Carlos_M_Intel
Hi a_Monteiro
Thanks for the logs, I would like to ask you some questions.
Did you install Anaconda before doing this? If you did, how did you do it?
I download the file you are using and check the INSTALL file, the correct command should be python setup.py install, did you try with this one too?
The error log mentions that it can't find resources for blas/lapack, have you tried to install these libraries?
http://netlib.org/blas/ BLAS (Basic Linear Algebra Subprograms)
http://netlib.org/lapack/ LAPACK — Linear Algebra PACKage
Did you check all the requirements for the package? http://www.scipy.org/stackspec.html# stackspec The SciPy Stack specification — SciPy.org
Charlie
AMont11
no I tried to do this after installing anaconda which comes with scipy already. I was able to install anaconda from the website : https://www.continuum.io/downloads Download Anaconda now! | Continuum . and then scp the folder to the edison and run the shell script file they made. I have to tried to install BLAS and LAPACK however i don't know how to install them after I upload them to the edison since there are only but .f files in the folders. I also have all of the other components in the anaconda package folder.
Carlos_M_Intel
Hi a_Monteiro
Let's try by installing https://github.com/xianyi/OpenBLAS OpenBlas, this should install BLAS and LAPACK, I also saw in your log the message:
NOT AVAILABLE
This could solve the dependencies for BLAS, LAPACK and OpenBlas.
For installing this you have to run the following commands:
If you have git:
git clone https://github.com/xianyi/OpenBLAS https://github.com/xianyi/OpenBLAS
cd OpenBLAS
Or you can download it with:
wget https://github.com/xianyi/OpenBLAS/archive/develop.zip https://github.com/xianyi/OpenBLAS/archive/develop.zip
unzip develop.zip
cd OpenBLAS-develop
Then, compile the library with: [https://github.com/xianyi/OpenBLAS/wiki/User-Manual User Manual · xianyi/OpenBLAS Wiki · GitHub]
make TARGET=ATOM
[Note: Targets List: https://github.com/xianyi/OpenBLAS/blob/develop/TargetList.txt OpenBLAS/TargetList.txt at develop · xianyi/OpenBLAS · GitHub]
Try this and let me know if it works for you, I'm currently compiling it too.
Charlie
AMont11
hi,
have you finished compiling it? If so, what was your result?
AMont11
I have finished compiling and the results of the compile is this but in doing what the instructions says to do further is not working:
OpenBLAS build complete. (BLAS CBLAS)
OS ... Linux
Architecture ... x86
BINARY ... 32bit
C compiler ... GCC (command line : gcc)
Library Name ... libopenblas_atomp-r0.2.16.dev.a (Multi threaded; Max num-threads is 2)
To install the library, you can run "make PREFIX=/path/to/your/installation install".
I tried make PREFIX=/home/root/ .. this does not work. What must I do, I'm not sure .
Admir M.
Carlos_M_Intel
Hi Admir M.
I got the same result as you, I ran make install and tried with a different PREFIX but I got some problems too.
I know you currently have scipy installed, which is the updates you want on your board? Do you want to change the version that you have? If this is the case, which version do you have?
Another thing you need to have in mind is the space available on the board. While trying to install scipy 0.17, Blas and Lapack in different ways I have had problems with this.
I found the way to install BLAS and LAPACK from source.
For BLAS: http://faculty.washington.edu/rjl/uwamath583s11/sphinx/notes/html/lapack_install.html Installing LAPACK and BLAS — AMath 483/583, Spring 2011 v1.0 documentation
wget http://www.netlib.org/blas/blas.tgz http://www.netlib.org/blas/blas.tgz
tar -zxf blas.tgz
cd BLAS
gfortran -O3 -c *.f
ar cr libblas.a *.o
For Lapack (I'm currently working on this): http://www.netlib.org/lapack/lawn41/node10.html Installing LAPACK on a Unix System & https://gcc.gnu.org/wiki/GfortranBuild GfortranBuild - GCC Wiki
wget http://www.netlib.org/lapack/lapack.tgz http://www.netlib.org/lapack/lapack.tgz
We need to change the make.inc and Makefile to make it work
Install Blas and start trying with Lapack, I will work on this too so we (probably) could use different approaches
Charlie
AMont11
I tried to install gfortran with opkg, it works but for some reason I cannot call it to install Blas.
thanks.
Carlos_M_Intel
Hi Admir M.
What is the output you are getting after gfortran -O3 -c *.f ? If you are receiving an error message, please post it.
Charlie
AMont11
hi,
I have fortran installed:
opkg install gfortran
Package gfortran (4.9.1-r0) installed in root is up to date.
but I try to run it ::
root@edison:~# gfortran -O3 -c *.f
-sh: gfortran: command not found
Carlos_M_Intel
Run the command opkg install gfortran-symlinks
Charlie
AMont11
When I run :gfortran -O3 -c *.f
Output :
gfortran: error: *.f: No such file or directory
gfortran: fatal error: no input files
compilation terminated.
Carlos_M_Intel
You need to run first the commands:
tar -zxf blas.tgz
cd BLAS-3.5.0
Be sure that you are located in that folder to be able to run gfortran, you should be able to see the .f files in that location. If you still have problems, delete the folder and the .tgz file, then download and extract the file again.
Charlie
AMont11
I ran the gfortran -O3 -c *.f command inside the BLAS folder and nothing for an output came out(No errors messages.)
Admir M.
Carlos_M_Intel
Hi Admir,
That is the expected behavior, after running the command you should be able to see the .o files in the folder.
I would like to know if you have been to update the scipy version you have. Could you tell us the version you have and the features you want to enable?
Charlie
AMont11
Hey CMata_Intel,
I had the older version but what i am going to do is delete my current version of anaconda. I then install it again and now it has all of the new module for python. I have done this on my laptop. The same then must be for linux.
Carlos_M_Intel
Hi Admir,
Did you try this? I would like to know if this worked for you
Charlie
AMont11
yes I did get a newer version of anaconda and newer version of spicy is on it. thanks !
