Intel® Makers
9872 Discussions
Urgente un problema con el boot!!!!!
aigna6
hola, cuando inicio mi placa no me sale nada
y cuando la reinicio me sale esto:
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
y despues el boot no se me inicia que hago!!!!!!!
Diego_V_Intel
Hello Alejandr34,
I recommend you to re-flash your Edison. You can do it by using the Flash Tool Lite. The Flash Tool Lite can be downloaded from the following site: https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone, and the Yocto image can be downloaded from the following link: http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip.
Diego.
aigna6
hola si lo hice pero me sale esto primero
y despues esto:
y el boton de "start to flash" esta desmarcado
que hago!!!!!
Diego_V_Intel
Let's try an alternative flashing method. This method uses a script called flashall. Check the following document to get additional details about how to perform this method:
Diego.
aigna6
si gracias pero
ya leí el articulo y sale que hay que ejecutar flashall.bat pero donde ahi que extraer la imagen yocto el la pc o la placa y que hay que hacer con la dfu-util.exe
me explicas mas detalladamente que hay que hacer
Diego_V_Intel
Sure. You have to decompress the image files in your PC and then, you have to download the dfu-util.exe file and copy it in the same folder where you decompressed the image files.
Once you have the image files and the dfu-util.exe file in the same folder in your PC, go to the command prompt (cmd.exe) and navigate to the folder where the image files are located. Connect the Edison board to your PC, and then run the flashall script by typing in the command prompt the following command: flashall.bat. The process should start and you can continue by following the instructions that appear in the command prompt.
Diego.
aigna6
si lo hice asi pero me sale esto
yo ya conecte y reinicie mi placa y luego me sale eso
Diego_V_Intel
Which USB port are you using to connect the board to your PC, and how are you powering it?
Diego.
aigna6
estoy usando ambos puertos usb y se esta alimentando con una fuente de 9 volts
Diego_V_Intel
Is your power source a battery or a wall adapter? If you are using a battery, I recommend you to use a DC wall adapter instead. Anyhow, this is a weird issue. Is this the first time you use the Edison, or were you able to use the Edison before without problems?
Diego.
aigna6
es una fuente dc de pared
Diego_V_Intel
Hello Alejandr34,
Is this the first time you try to use the Edison, or you were able to use the Edison before?
Could you take a screenshot of the Device Manager while both USB cables are connected to the PC? I would like to check the status of the COM ports associated to the Edison board.
Diego.
