Hi -Leonardo,
At this last moment of the topic you promised to give instructions on the transposition of the project to eclipse ide
I know about use devkit-launcher.bat to start, But what about smartdrive project upm (with Cmakelist.txt and so on)
I need this to adapt this project: http://www.instructables.com/id/Use-of-GPS-and-Hall-sensor-with-the-Edison/ Use of GPS, hall sensor, LEDs and Firebase with the Edison
using Firebase to my project (backend firebase)
- Tags:
- Sensors
Hi Neuberfran,
Can you please try to explain us a little bit more your issue? You're making this thread so confusing, because you ask about one thing and the other reply is about a different problem. Please try to explain one issue at a time to assist you in a better way.
Have a nice weekend.
-Leonardo
Hi Neuberfran,
I need your explanation to help you more.
If you have a different questions, I suggest you to create a thread for each one to avoid confusions.
Have a nice day.
-Leonardo
Hi -Leonardo,
I need your tutorial do create a upm sensor using eclipse ide. I know about devkit-launcher.bat to start eclipse ide.
I need step by step
Hi Neuberfran,
To use ISS IoT there is a lot of documentation that you can check here: https://software.intel.com/en-us/intel-system-studio-iot-edition-guide-for-c, I recommend you to take a look at it.
About using UPM sensors with it, I found this guide that can be useful for you: https://software.intel.com/en-us/working-with-sensors-in-intel-system-studio-iot-edition.
I hope this information helps you.
Have a nice day.
-Leonardo
