Hello!
How to use qmsi driver in Zephyr project.
I want to use qmsi driver that placed in ext folder from Zephyr in ISSM.
But if I add # include
in build i have - fatal error: qm_pwm.h: No such file or directory.
Step by step
1. Open ISSM
2. File->new->Intel project for microcontroller
3. Intel Quark SE C1000
4. Zephyr Project (1.4)
5. Zephyr Nano Kernel
6. Drivers->GPIO
7. Finish generate project
and me need use timer with interrupt every 1ms.
Quark SE C1000 have 4 timer/counter I want to use this timers. Zephyr driver not provide interface for this in qmsi have this timer.
Please help me configure ISSM for use qmsi function in my src.
Hi, I am having a similar issue. I have found part of the solution:
modify your prj.conf to add your particular Zephyr configuration parameters: In my case I want to add (External) QMSI BSP 1.1.0 to the Zephyr Philosopher example: so I did this:
# These are Zephyr project configuration items - to include the external QMSI BSP...
CONFIG_QMSI=y
CONFIG_QMSI_INSTALL_PATH="/Philosophers/zephyr/ext/hal/qmsi"
CONFIG_HAS_QMSI=y
CONFIG_QMSI_BUILTIN=n
CONFIG_QMSI_LIBRARY=y
I am still having issues with the CONFIG_QMSI_INSTALL_PATH parameter, but the above steps are valid.
This query is answered in this thread -
