Intel® Makers
9874 Discussions
Using DMA with ADC on quark C1000
bbogu1
I was wondering if there is possibility to use DMA only to work with ADC on quark C1000? The ADC is inside the Sensor subsystem and the documentation for DMA states the hardware handshakes for UARTs, SPIs, I2S and I2Cs.
The example code only shows polling and interrupt examples. If you have same example code which is not added to ISSM for that it would be even better.
Malcolm_P_Intel
Hi Bartosz,
The hardware on C1000 for DMA does not support ADC transactions.
As you stated, the supported peripherals are listed in the datasheet as UARTs, SPIs, I2S and I2Cs
Malcolm Prinn
Michelle_C_Intel
Hi Bartosz
We are currently looking into this - I'll get back to you as soon as I have any update.
-- Michelle.
Malcolm_P_Intel
Hi Bartosz,
Malcolm Prinn
