Hello Everyone. My question regards to using Edison and Arduino to program the Edison on a different computer that doesn't have anything installed. That other computer would be something like one from school that you cant install much on. I have a flash drive that I can use to put arduino on and all that information. Thank You
Hello Roentgenium111,
If you want to use the Edison on another PC, you won't be able to use the Arduino IDE without installing http://downloadmirror.intel.com/24909/eng/IntelEdisonDriverSetup1.2.1.exe the Edison's driver. If the computer has http://www.ftdichip.com/Drivers/D2XX.htm the FTDI driver installed by default, you will be able to access the Edison's console, where you can install mraa (if you have access to the internet on your board) and use it to compile code in C, Python, Node.JS, etc. If the FTDI driver is not installed, then your last option would be for you to SSH into your Edison and you will be to also access your Edison's console. Nevertheless, accessing your board's console through a USB port or through SSH will require to have PuTTY or any other similar software installed.
So, I believe that your best option would be to find a portable version of PuTTY (or any other similar software) so you don't have to install anything and access your board through SSH.
Peter.
Peter.
