Intel® Makers
Using Fedora
Ashish_G_Intel
I am facing difficulty while using Fedora for Edison. The Intel ISS IOT Eclipse based IDE is not getting launched.
I am using the latest version - Fedora 24 with iss-iot-linux_03-24-16.tar.bz2
Java installation is fine, JAVA path is getting setup fine, in fact I also tried the latest standard Eclipse Neon IDE with CDT plugin and it works fine.
But the Intel ISS IOT IDE does not get launched. When I run the launcher, I don't get any errors, still no eclipse window opens up.
Can someone please help resolve.
thanks
Ashish
Community Manager
Hi AshishG,
So, did you followed all the steps on https://software.intel.com/en-us/installing-the-intel-system-studio-iot-edition https://software.intel.com/en-us/installing-the-intel-system-studio-iot-edition and still can't open the IDE? There's a section about launching the IDE for each OS, so make sure you're launching correctly.
When you try to open the IDE do you see a terminal window open and the close? If that's the case take a look at https://software.intel.com/en-us/intel-system-studio-iot-edition-troubleshooting-and-faq# I_cant_open_Eclipse https://software.intel.com/en-us/intel-system-studio-iot-edition-troubleshooting-and-faq# I_cant_open_Eclipse
Let us know your results.
-Sergio
Community Manager
Do you still need assistance with this thread? Were you able to use the Eclipse IDE?
-Sergio
Ashish_G_Intel
Yes I still need help with this issue.
1. Yes, I did follow all the steps on that link for Linux OS, specifically below:
Linux
  1. Download the https://software.intel.com/en-us/iot/software/ide Intel System Studio IoT Edition installer file for Linux.
  2. Open a new Terminal window.
  3. Navigate to the directory that contains the installer file.
  4. Enter the command: tar -jxvf file to extract the tar.bz2 file, where file is the name of the installer file. For example, tar -jxvf iss-iot-linux.tar.bz2. The command to enter may vary slightly depending on the name of your installer file.
  5. Then tried launching using script iss-iot-launcher.sh.
2. Nope, I don't see a command window open / close.
3. Additional info
Standard Eclipse Neon with CDT downloaded from eclipse.org, works perfectly fine.
regards
Ashish
Community Manager
In what path have you installed the IDE? There might be issues if any of the folder names have spaces. Make sure there are no spaces in the file path.
Are you executing the IDE as a super user with the use of the sudo command?
-Sergio
Community Manager
Do you still need help with this thread, were you able to use Eclipse in Fedora?
-Sergio
Ashish_G_Intel
Still facing issues:
- In what path have you installed the IDE? There might be issues if any of the folder names have spaces. Make sure there are no spaces in the file path.
Tried multiple - /opt and /home
Tried both SU and normal user
Again, as I mentioned above, the environment works fine with Eclipse Neon with CDT directly downloaded from Eclipse.org without the Intel plugins.
Have you been able to replicate my issues at your end with Fedora 24?
regards
Ashish
Community Manager
We'll investigate on this and post a reply soon.
-Sergio
Community Manager
Thank you for your patience. The Intel ISS IOT Eclipse based IDE has been validated with Ubuntu LTS (14). The document list of requirements is missing this information, we're working to update this document. Fedora is not a compatible OS.
-Sergio
