Intel® Makers
9881 Discussions
Using Ostro OS + Serial CDC
Community Manager
Hello Everybody,
In my quest to using Intel's Wireless AC-3160 wifi PCIe card with the Galileo, I compiled the swupd version of Ostro OS and everything seemed to work well except for the Serial port.
My USB CDC device does not appear as an ACMx file interface (/dev/ttyACM0 for example). Has anyone had similar problems with kernel 4.4?
I've put some commands I ran, that might help the context at the end of this post. The device in question is the STMicroelectronics STM32F407. I can confirm that reverting to the standard image for the Galileo fixes this issue.
Thank you...
# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 8087:07dc Intel Corp.
Bus 002 Device 002: ID 0483:5740 STMicroelectronics STM32F407
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
# lsusb -d 0483:5740 -v # for STM32F407
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0483 STMicroelectronics
idProduct 0x5740 STM32F407
bcdDevice 2.00
iManufacturer 1 STMicroelectronics
iProduct 2 STM32 Virtual ComPort
iSerial 3 00000000001A
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 67
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 250mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x02
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
# cat /dev/tty
tty tty11 tty15 tty19 tty22 tty26 tty3 tty33 tty37 tty40 tty44 tty48 tty51 tty55 tty59 tty62 tty9 ttyS2
tty0 tty12 tty16 tty2 tty23 tty27 tty30 tty34 tty38 tty41 tty45 tty49 tty52 tty56 tty6 tty63 ttyGS0 ttyS3
tty1 tty13 tty17 tty20 tty24 tty28 tty31 tty35 tty39 tty42 tty46 tty5 tty53 tty57 tty60 tty7 ttyS0
tty10 tty14 tty18 tty21 tty25 tty29 tty32 tty36 tty4 tty43 tty47 tty50 tty54 tty58 tty61 tty8 ttyS1
Community Manager
Hi Taimoor,
Thanks for your interest in the Intel Galileo Platform.
Unfortunately the scooped of our support is limit to the Yocto default image. Nevertheless I encourage you to contact the Ostro community in this link: (https://github.com/ostroproject/ostro-os/search?q=galileo&type=Issues&utf8=%E2%9C%93 Search Results · GitHub ).
I hope you find this information useful, have a nice day!
-Jose.
Community Manager
Hello Jose,
Thanks for your response. Generally however, do you think I will see problems with Kernel 4.x and CDC devices? Are there driver packages I should not forget to include in the Yocto build?
Thanks!
Community Manager
Hi Taimoor,
I have just checked the kernel version of the default Yocto image and it is 3.7.8 (See the image attach below). We have not tested any other kernel version, so we are not sure how the CDC drivers will behave.
Still if you want to test it, I would encourage you to share your results with the community, since it may benefit other users.
I hope you find this information useful, we hope you have a nice day!
-Jose.
Community Manager
Hey Jose,
Yeah, thanks for your help. FYI.. here's where I reached a potential solution: https://github.com/ostroproject/ostro-os/issues/214 Using Ostro OS + Serial CDC · Issue # 214 · ostroproject/ostro-os · GitHub
I'll get back here when I observe success (which is evading me until now)...
Best,
T
Community Manager
Hello Jose,
Take a look at the link above. I think the resolution was found!!
Community Manager
Hi Taimoor,
I'm glad to hear that a solution was found! If you have any more questions regarding the Intel Galileo, please let us know in order to assist you.
Have a nice day!
-Jose.
