Intel® Makers
9868 Discussions
Using UART to interface a GSM module
JTori
Hello!
I'm starting to work with D2000 uC and I want to connect UART_A to a GSM module and send AT commands. I've done this with other uCs (Cortex-M0, AVR). I read everything I've found about UARTS in d2000 uC and I have some questions. I'm used to write my own tx/rx interrupts and work with a FIFO for tx and another for RX. I'm looking for the correct way to code my app using QMSI.
For example, the "hello world" with a gsm module is to send AT and receive OK.
The transmit part is easy: qm_uart_write_buffer(QM_UART_0, (uint8_t *)"AT\n\r",sizeof("AT\n\r"));
After that command, the module takes some time to answer and send the OK string.
1- the OK string will be available on the RX buffer or should I request a non-blocking IRQ RX transfer? I used to send and wait for a time-out, then analyze the RX buffer for the OK string.
2- if yes, how can I read the RX buffer directly ?
3- if no, I need to setup a xfer, but in the xfer I need to specify the data lenght, but I don't always know the length of the data that I will receive.
thank you,
Jorge.
Pablo_M_Intel
Hi Jorge,
I believe the second approach would be the correct one to use, request a non-blocking IRQ RX transfer. I'm not sure if you have checked the GitHub examples about UART, if not here's the link https://github.com/quark-mcu/qmsi/blob/master/examples/uart/main.c https://github.com/quark-mcu/qmsi/blob/master/examples/uart/main.c. In that example they set an async_xfer_desc variable, setting the data, data length and callback.
Now to define the xfer, I can't think of an exact way to resolve this issue, but a possible workaround would be to set the length according to the maximum length of the buffer and set a signal that tells when the data has finished.
-Pablo
Pablo_M_Intel
Hi Jorge,
-Pablo
JTori
Thank you Pablo! I will check the example.
