Intel® Makers
9881 Discussions
Using read and write with mraa
AARAV
I'm using the mraa uart library to setup a serial connection. However, I need access to the file descriptor once the connection has been established as I need to use the select() function from the standard c library to check if there is any data on the serial port.
I tried to access the file descriptor via the mraa_uart_context and I'm not able to, for some reason. Is there a way to do this via the mraa library itself? Or is there a way to access the file descriptor once the connection has been established via mraa_uart_init_raw?
Any help would be appreciated.
Aravind
PS: this is my gdb log. 'uart' is of type mraa_uart_context. However, when I try to print it's members, nothing comes up.
p uart
$1 = (mraa_uart_context) 0x805a9a0
ptype uart
type = struct _uart {
Community Manager
Hi Aravind,
Thank you for contacting us, let us try to help you.
I would like to know if you have seen these two threads before https://communities.intel.com/thread/77148 https://communities.intel.com/thread/77148 and https://communities.intel.com/thread/57503 https://communities.intel.com/thread/57503. In the first one, there are provided some examples to use UART with MRAA, you can check that code, you might find something useful. The other one, explains a way to do it from the Arduino IDE that you might want to try too.
-Pablo M.
AARAV
Hi Pablo,
Thanks for responding. I did look at the first thread. But I think it has some additional links that focus only on the mraa read and write apis. I need to use something like the select() function which would allow me to check if there is any data on the serial port. I cannot find an equivalent function with the mraa library to do that. If you know of something like that, that would be very helpful.
Aravind
Community Manager
Hi Aravind,
I've been doing some research on using the select() function to know if there's any data on the serial port and haven't found much really, I found a link with some information though https://software.intel.com/en-us/articles/internet-of-things-using-mraa-to-abstract-platform-io-capa... https://software.intel.com/en-us/articles/internet-of-things-using-mraa-to-abstract-platform-io-capa.... There's an UART example at end that mentions the following "Using read() and write() directly will block if there is nothing available to read. To avoid this blocking behavior, in most cases, you will want to create a function that can check to see if data is available before trying a read. This can be accomplished using the select() system call. See the UPM wt5001 driver for an example. This capability is implemented as a method called dataAvailable()".
I'm wondering if you have checked the files where this is, https://github.com/intel-iot-devkit/upm/blob/master/src/wt5001/wt5001.cxx https://github.com/intel-iot-devkit/upm/blob/master/src/wt5001/wt5001.cxx. If not, you can find it attached: bool WT5001::dataAvailable(unsigned int millis) { if (m_ttyFd == -1) return false; struct timeval timeout; // no waiting timeout.tv_sec = 0; timeout.tv_usec = millis * 1000; fd_set readfds; FD_ZERO(&readfds); FD_SET(m_ttyFd, &readfds); <span style="color: # A71D5D; font-size: 9.0pt; font-...
Community Manager
Hello Aravind,
Do you have updates on this case?
Pablo M.
