Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Using xsens imu from usb
I'm using an intel edison with an arduino expansion board to connect a xsens mti sensor through the USB port, but when I do ls /dev/tty* the device is not present. Then I do a lsusb and it is present but no driver is associated.
I yet build a custom kernel (using menuconfig) to embedded the xsens motion control driver, but does not work.
Has anyone experienced similar problem?
Thank's
Rafael
Community Manager
Hi Rafael,
Thank you for contacting us!
I'll try to help you with that, in order to give you a better assistance I would like to know the detailed steps you followed in order to modify the kernel.
I'll be waiting your reply.
-Yermi
Community Manager
Hi Yermi,
I followed these steps:
Download last source files from intel site (ww25.5), extract and configure bitbake directories, run ./meta-intel-edison/setup.bashEdit the paho-mqtt_3.1.bb file to change the SRC_URI variable$bitbake virtual/kernel -c menuconfigDevice Drivers > USB support > USB Serial Converter support > Xsens motion tracker serial interface driver (M)Save the .config file and copy the changes from tmp/work/edison-poky-linux/linux-yocto/3.10.17-r0/linux-edison-standard-build/.config to tmp/work/edison-poky-linux/linux-yocto/3.10.17-r0/linux/arch/x86/configs/i386_edison_defconfig$ bitbake virtual/kernel -c configure -f -v$ bitbake edison-imageEdit meta-intel-edison/utils/create-debian-image.sh with these changes:build_dir=$top_repo_dir/build to build_dir=$top_repo_dir/out/linux64/build
fsize=$((`stat --printf="%s" toFlash/edison-image-edison.ext4` / 524288)) to fsize=$((`stat --printf="%s" toFlash/edison-image-edison.ext4` / 524288 * 2))
And then flash the image to the Edison
When I run the lsusb command the xsens is present, but without the xsens driver. When I go to the drivers/usb/serial directory the xsens_mt driver is not here.
Thank you!
* I'm building a new image and I will post the shell print screen.
Community Manager
Hi Rafael,
Thank you very much for your detailed reply, it seems that you are following the correct steps and it is strange that xsen_mt driver is not present. I've noticed that you are building the driver as a module (M), I'd suggest you to try to build it as compiled-in (y) in order to know if it could help.
Moreover, I'll be waiting for your post with the shell print screen, also, any detail you can share will be very useful.
-Yermi
Community Manager
Hi Rafael,
I would like to know if you have any questions or update.
-Yermi
