- Email to a Friend
Hi, Im jaeuk Lee from South Korea.
I try to connected VL53L0X (data sheet : http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/D... http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/D...…)
And I read some source from GitHub (https://github.com/popunder/VL53L0X/blob/master/VL53L0Xtest.py VL53L0X/VL53L0Xtest.py at master · popunder/VL53L0X · GitHub , https://github.com/victorchinn/VL53L0X/blob/master/vl53l0x.py VL53L0X/vl53l0x.py at master · victorchinn/VL53L0X · GitHub , https://github.com/pololu/vl53l0x-arduino/blob/master/VL53L0X.h vl53l0x-arduino/VL53L0X.h at master · pololu/vl53l0x-arduino · GitHub )
but I confused about VL53L0X register map ST company didn't published a register map. So their are my code and compile screen shot.
User's source tell me Distance read register = 0x14 but 'I think' 0x14 is not reveal some data
how can I solved these problem?
thank you
- Email to a Friend
Hello Jaeuk,
Thank you for your interest in the Intel® Edison Breakout Board.
I have to inform you that code debugging is out of the scope of our technical support team.
Although, I may be able to provide some insight. What I understand from your post is that you can't get any output from register 0x14. I checked the links you provided (specifically the one showing VL53L0Xtest.py) and saw that accessing register 0x14 has to be done through the bus.read_i2c_block_data() function.
If you have any other update or question related to the Edison module itself, don't hesitate to contact us.
Have a nice day.
Andres V.
- Email to a Friend
Hello Jaeuk,
Have a nice day.
Andres V.
