Intel® Makers
9874 Discussions
VPN connection on Edison board
RKasu
Hi all,
I'm using http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/about meta-intel-edison - Layer for the Intel Edison Development Platform image on my intel edison arduino expansion board,I'm trying to connect my edison by VPN. I have tried two methods ,they are
Method-1:
I'm unable to connect to vpn as there is no script loading into vpn-script after ./configure and I'm getting the error as mentioned in the link https://bugs.kde.org/show_bug.cgi?id=348318 https://bugs.kde.org/show_bug.cgi?id=348318
POST www.google.com
Attempting to connect to server 144.92.42.108:443
SSL negotiation with dept-ra-cssc.vpn.wisc.edu
Server certificate verify failed: signer not found
SSL connection failure: Error in the certificate.
Failed to open HTTPS connection to dept-ra-cssc.vpn.google.com
I'm tried the same open connect command by no-certi-check but it is not working.
Method:2
https://www.snip2code.com/Snippet/996017/Openvpn-Intel-Edison-Yocto https://www.snip2code.com/Snippet/996017/Openvpn-Intel-Edison-Yocto
I got a doubt whether it works for my image or not.I'm using the image http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/about meta-intel-edison - Layer for the Intel Edison Development Platform .I followed the same process as mentioned in the link,the error I'm getting is in the below image
Can you please suggest me the steps to connect the edison to VPN.Please do needful.Hope the answer is helpful.
Thanks and Regards,
Radhika
RKasu
Hi all,
I'm adding some more details.I'm following the link ,here in the vpn-script I'm copying the sh file from the link http://git.infradead.org/users/dwmw2/vpnc-scripts.git/blob_plain/HEAD:/vpnc-script http://git.infradead.org/users/dwmw2/vpnc-scripts.git/blob_plain/HEAD:/vpnc-script and following the steps
wget ftp://ftp.infradead.org/pub/openconnect/openconnect-7.06.tar.gz ftp://ftp.infradead.org/pub/openconnect/openconnect-7.06.tar.gz && tar xvf openconnect-7.06.tar.gz && cd openconnect-7.06 && ./configure --with-vpnc-script=/etc/vpnc/vpnc-script && make && make install
chmod u+x /etc/vpnc/vpnc-script
openconnect -s /etc/vpnc/vpnc-script vpn.myschool.edu
But I'm getting the same error
I tried to install vpnc and installed the dependencies but it failed because of the error,The screenshots are pinned,please have a look on them.
Can you please provide the steps to install vpnc or vpnc-script.If I'm just copy pasting the script file and pasting in vpnc-script it is not working and getting the above mentioned error and no signer found.
Can I know the steps to install openvpn on edison ?If I'm trying through opkg install openvpn it is showing as unknown package.I have the packages listed below in intel-iotdk.conf file
src intel-iotdk http://iotdk.intel.com/repos/1.1/intelgalactic
src intel-all http://iotdk.intel.com/repos/1.1/iotdk/all
src intel-quark http://iotdk.intel.com/repos/1.1/iotdk/quark
src intel-i586 http://iotdk.intel.com/repos/1.1/iotdk/i586
src intel-x86 http://iotdk.intel.com/repos/1.1/iotdk/x86
Please do needful by giving the detailed steps of connection of VPN to edison. Thanks in advance.
Thanks and Regards,
Radhika.
Sergio_A_Intel
Hi Radhika,
I ran the steps on the link you mentioned and didn't see any errors. These are the steps I followed:
1. wget ftp://ftp.infradead.org/pub/openconnect/openconnect-7.06.tar.gz && tar xvf openconnect-7.06.tar.gz && cd openconnect-7.06 && ./configure --with-vpnc-script=/etc/vpnc/vpnc-script && make && make install
2. mkdir /etc/vpnc
3. nano vpnc-script
4. chmod u+x /etc/vpnc/vpnc-script
5. openconnect -s /etc/vpnc/vpnc-script vpn.myschool.edu
All these steps have to be run just as they are described here except for the last one where you have to use your own vpn server name. What VPN server name are you using? Do you see any errors when running any of the previous commands? I ran these commands with the latest image. Why are you using this image instead of the provided here https://software.intel.com/en-us/iot/hardware/galileo/downloads https://software.intel.com/en-us/iot/hardware/galileo/downloads? Run the commands above and if any of them give an error please attach a screenshot.
-Sergio
RKasu
Hi Sergio,
Thanks for the reply,I followed the same process and I'm getting the result as below.I have installed vpnc-scripts from https://github.com/alonbl/vpnc-scripts GitHub - alonbl/vpnc-scripts .
If I'm changing the server name I'm getting as
Is there any other way to install vpnc-script.?After the step openconnect -s /etc/vpnc/vpnc-script vpn.myschool.edu, will the server asks for username and password??
Is the actual output is this??
I'm using latest image only..Can you please look into the above 3 screenshots and figure what's wrong in this?? what is the image you are using?If we should install vpnc-script ,what is the process should be followed for vpnc-script??
Thanks and Regards,
Radhika
Community Manager
Hi Radhika,
I tested the VPN connection using the vpnc-script you posted in the last reply but ended up with a similar issue to yours. My error was the following:
root@TQFGOD:/etc/vpnc# openconnect -s /etc/vpnc/vpnc-script www.google.com
POST https://www.google.com/ https://www.google.com/
Attempting to connect to server 216.58.219.100:443
SSL negotiation with www.google.com
Certificate from VPN server "www.google.com" failed verification.
Reason: signer not found
Enter 'yes' to accept, 'no' to abort; anything else to view: yes
SSL connection failure: The operation timed out
Failed to open HTTPS connection to www.google.com
Failed to obtain WebVPN cookie
I looked at my openconnect version. I'm using v7.06. In one of your screenshots there's a warning message that says:
"This version of openconnect is v7.06 but the libopenconnect library is v7.07"
Have you tried upgrading your openconnect so that it matches the libopenconnect library? Upgrade it and let us know if you continue to see the same results. Post screenshots of your progress.
We'll be waiting for your response.
-Sergio
RKasu
Hi Sergio,
I have changed the version of the open connect but still the error seems to be the same..can you please let us know Can I connect to vpn. Please do needful.
Thanks and Regards,
Radhika.
Community Manager
If you don't require the server SSL certificate to be valid you can use the –no-check-cert option. If your certificate information has a server key hash you can use the --servercert=FINGERPRINT option. You can also ask about openconnect here http://www.infradead.org/openconnect/mail.html http://www.infradead.org/openconnect/mail.html . They might be able to provide a more accurate response.
Let us know what are your results and if you contacted openconnect.
-Sergio
Community Manager
Hi Radhika,
Do you still need assistance with this case? Were you able to set the VPN connection?
-Sergio
KDuns1
I am having same issue when I tested using VPNC Script.
Hi all,
Method-1:
/thread/57481 How can I setup a VPN in my edison board?
https://support.purevpn.com/windows-setup-guide How can I setup a VPN on Windows
I'm unable to connect to vpn as there is no script loading into vpn-script after ./configure and I'm getting the error as mentioned in the link https://bugs.kde.org/show_bug.cgi%3Fid%3D348318 https://bugs.kde.org/show_bug.cgi?id=348318
POST www.google.com
Method:2
/servlet/JiveServlet/showImage/2-424518-295077/error_vpn1.png
Thanks and Regards,
Radhika
Community Manager
Hi KirstenDunst,
Could you provide more details on what you've tried so far? What image are you using, what's the output of running cat /etc/version? Have you already upgraded openconnect to v7.07 ?
-Sergio
