Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Watchdog in edison
Jump to solution
Hi. I'm trying to make an example of watchdog as explaining this link in the intel edison: https://bigdanzblog.wordpress.com/2014/10/24/arduino-watchdog-timer-wdt-example-code/ Arduino Watchdog Timer (WDT) Example Code | Big Dan the Blogging Man
But the following line causes an error: # include
The version IDE of Arduino is 1.6.0. How I can get the library avr/wdt ?
Thanks in advance.
Community Manager
Hi Javilez,
There is a problem with the AVR libraries, they are not compatible with the x86 architecture. This is an issue that happens a lot so you can look this thread: https://communities.intel.com/thread/57366 https://communities.intel.com/thread/57366. In the thread there is a suggestion about re-write the libraries to work for the Edison architecture.
I hope you find this information useful.
-Leonardo
Community Manager
Hi Javilez,
-Leonardo
