Community
cancel
Showing results for
Search instead for
Did you mean:
RVaid
We have prepared the code in Arduino IDE and are trying to dump the code on to the board.The board will be interfaced with GSM SIM900A and GPRS module and an accelerometer ADXL 335. The code is written using SoftwareSerial.h library package to enable the
Jump to solution
The code is written using SoftwareSerial.h library package to enable the serial communication with the external Interface.But since this board does not support this file, there is a fatal error being flashed every time we try to compile.So what is the alternate library package that can be used?
Otherwise do we have to go with hardware connection to FTDI ports?
Carlos_M_Intel
Hi RohiniBMSCE23,
Let's try with this one. It is a workaround that may help you on your project. -> https://github.com/MakersTeam/Galileo/tree/master/Arduino-Examples/SoftwareSerial Galileo/Arduino-Examples/SoftwareSerial at master · MakersTeam/Galileo · GitHub
Things to be considered
  • This workaround only work for Galileo Gen2.
  • Only the pins 2 and 3 can be used for this purpose.
  • The directory SoftwareSerial_Gen2 contains the files SoftwareSerial.cpp and SoftwareSerial_Class.h. This directory has to be copied in the Arduino libraries folder.
[https://github.com/MakersTeam/Galileo/tree/master/Arduino-Examples/SoftwareSerial Source]
Charlie
Carlos_M_Intel
Hi RohiniBMSCE23,
Charlie
RVaid
Yes connection is made only with pin 2 and 3 , but do whatever one might Softwareserial is not supported ! Its saying a fatal error.!Pls do suggest some othe work way !
Carlos_M_Intel
Hi RohiniBMSCE23,
Which Arduino IDE version are you using? Also, could you post the entire error you are getting?
Charlie
