Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Web server rejected a connection
I want to create a web server that will update a value of analog input on a page. The problem is that when I'm refreshing the page the second or third time, the system fails and I've got this message:
Server 192.168.0.100 rejected connection.
What can cause this error? I use AJAX requests to update the value automatically.
void GetAjaxData(EthernetClient cl) {  int analog_val;  // read analog pin A0  analog_val = analogRead(0);  cl.print("Analog 0: ");  cl.print(analog_val);  cl.println(""); }  void loop() {  EthernetClient client = server.available(); // try to get client  if (client) { // got client?  boolean currentLineIsBlank = true;  while (client.connected()) {  if (client.available()) { // client data available to read  char c = client.read(); // read 1 byte (character) from client  HTTP_req += c; // save the HTTP request 1 char at a time  // last line of client request is blank and ends with \n  // respond to client only after last line received  if (c == '\n' && currentLineIsBlank) {  // send a standard http response header  client.println("HTTP/1.1 200 OK");  client.println("Content-Type: text/html");  client.println("Connection: keep-alive");  client.println();  // AJAX request for switch state  if (HTTP_req.indexOf("ajax_switch") > -1) {  // read switch state and analog input  GetAjaxData(client);  } else { // HTTP request for web page  // send web page - contains JavaScript with AJAX calls  client.println("<!DOCTYPE html>");  client.println("");  client.println("");  client.println("Arduino Web Page");  client.println("");  client.println("function GetSwitchAnalogData() {");  client.println(  "nocache = \"&nocache=\" + Math.random() * 1000000;");  client.println("var request = new XMLHttpRequest();");  client.println("request.onreadystatechange = function() {");  client.println("if (this.readyState == 4) {");  client.println("if (this.status == 200) {");  client.println("if (this.responseText != null) {");  client.println("document.getElementById(\"sw_an_data\")\.innerHTML = this.responseText;");  client.println("}}}}");  client.println(  "request.open(\"GET\", \"ajax_switch\" + nocache, true);");  client.println("request.send(null);");  client.println("setTimeout('GetSwitchAnalogData()', 200);");  client.println("}");  client.println("");  client.println("");  client.println("");  client.println("Arduino AJAX Input");  client.println("");  client.println("");  client.println("");  client.println("");  }  // display received HTTP request on serial port  Serial.print(HTTP_req);  HTTP_req = ""; // finished with request, empty string  break;  }  // every line of text received from the client ends with \r\n  if (c == '\n') {  // last character on line of received text  // starting new line with next character read  currentLineIsBlank = true;  } else if (c != '\r') {  // a text character was received from client  currentLineIsBlank = false;  }  } // end if (client.available())  } // end while (client.connected())  delay(1); // give the web browser time to receive the data  client.stop(); // close the connection  } // end if (client) }
Tags (1)
Community Manager
Re: Web server rejected a connection
Hi michalt38,
Thank you for contacting Intel Customer Support.
Could you please give me more details about what you are trying to do?
Alexandra
Highlighted
I want to enter an Edison IP address in a web browser and see a page on which will be displayed an actual value on analog input A0. This value should be updated automatically every 0,2 ms (more or less) without refreshing a page.
Highlighted
Community Manager
Hi michalt38,
It seems to be a problem with your code, we can't debug it or fix it for you.
Alexandra
