Intel® Makers
9872 Discussions
Weird Problem when measuring MPU9150 IMU sensor
FPhil
Hi guys,
So I am trying to get measurements from the MPU-9150 sensor from Invensense using the Intel Edison. I am able to communicate with the sensor and the values seem sensible.
But after a specific number of cycles, I measure only a zero from all data registers. This error is repeatable: When I try to read the Accelerometer and Gyro data(6 data registers), the data stream stops exactly at 84 cycles. If I try to read jus the Accelerometer values, it stops at double the no. of cycles i.e. 168. I sense some data is overflowing, but couldn't figure out yet.
Looking for your reply and Thanks!
Cheers,
Frederic
Code:
MPU9150.h
//Self Test registers R/W
# define SELF_TEST_X 0x0D
# define SELF_TEST_Y 0x0E
# define SELF_TEST_Z 0x0F
# define SELF_TEST_A 0x0A
//Configuration Registers
# define SMPRT_DIV 0x19 //Sample Rate Divider
# define CONFIG 0x1A //FSYNC & DLPF config
# define GYRO_CONFIG 0x1B //Self-Test & Scale select
# define ACCEL_CONFIG 0x1C //Self-Test & Scale select
//Interrupt Registers
# define INT_ENABLE 0x38
# define INT_STATUS 0x3A
//Accelerometer Measurement Registers
# define ACCEL_XOUT_H 0x3B
# define ACCEL_XOUT_L 0x3C
# define ACCEL_YOUT_H 0x3D
# define ACCEL_YOUT_L 0x3E
# define ACCEL_ZOUT_H 0x3F
# define ACCEL_ZOUT_L 0x40
//Temperature Measurement Registers
//Temperature in degrees C = (TEMP_OUT Register Value as a signed quantity)/340 + 35
# define TEMP_OUT_H 0x41
# define TEMP_OUT_L 0x42
//Gyroscope Measurement Registers
# define GYRO_XOUT_H 0x43
# define GYRO_XOUT_L 0x44
# define GYRO_YOUT_H 0x45
# define GYRO_YOUT_L 0x46
# define GYRO_ZOUT_H 0x47
# define GYRO_ZOUT_L 0x48
//Power Management Registers
# define PWR_MGMT_1 0x6B
# define PWR_MGMT_2 0x6C
//Device i.d. Register
# define WHO_AM_I 0x75
R1 - 0x69
R2 - 0x68
# define MPU_ADDR 0x68
//Reset the Registers and Power
# define PWR_RESET 0x80
# define DEVICE_ON 0x00
//Accelerometer Scale
# define ACCEL_2G 0x00
# define ACCEL_4G 0x08
# define ACCEL_8G 0x10
# define ACCEL_16G 0x18
//Gyroscope Scale
# define GYRO_250 0x00
# define GYRO_500 0x08
# define GYRO_1000 0x10
# define GYRO_2000 0x18
# define SAMPLE_RATE 0x00
# define DLPF_CFG 0x01
MPU9150.c
# include
# include
# include
# include "mraa.h"
# include "MPU9150.h"
void MPU9150_I2C_Init(void);
void MPU9150_I2C_Config(void);
void MPU9150_I2C_Write(uint8_t address, uint8_t value);
void MPU9150_I2C_Read(uint8_t address, uint8_t *value);
int16_t MPU9150_Get_Measurement(uint8_t addrL, uint8_t addrH);
void sig_handler(int signum);
sig_atomic_t volatile isrunning = 1;
//Acceleometer Measurement Storage Variables
int16_t Accel_X = 0;
int16_t Accel_Y = 0;
int16_t Accel_Z = 0;
//Gyroscope Measurement Storage Variables
int16_t Gyro_X = 0;
int16_t Gyro_Y = 0;
int16_t Gyro_Z = 0;
//Temperature Measurement Storage Variable
float Temperature = 0;
//Variable to Store LOW and HIGH Register values
uint8_t Measurement_L = 0;
uint8_t Measurement_H = 0;
int main(int argc, char **argv)
printf("--------------------------------------------------\n");
printf("------------------eGlove Project------------------\n");
sleep(1); //1s delay
signal(SIGINT, &sig_handler);
usleep(1000); //1ms delay
MPU9150_I2C_Init();
MPU9150_I2C_Config();
while(isrunning)
//Get Accelerometer Measurements
Accel_X = MPU9150_Get_Measurement(ACCEL_XOUT_L, ACCEL_XOUT_H);
Accel_Y = MPU9150_Get_Measurement(ACCEL_YOUT_L, ACCEL_YOUT_H);
Accel_Z = MPU9150_Get_Measurement(ACCEL_ZOUT_L, ACCEL_ZOUT_H);
//Get Gyroscope Measurements
Gyro_X = MPU9150_Get_Measurement(GYRO_XOUT_L, GYRO_XOUT_H);
Gyro_Y = MPU9150_Get_Measurement(GYRO_YOUT_L, GYRO_YOUT_H);
Gyro_Z = MPU9150_Get_Measurement(GYRO_ZOUT_L, GYRO_ZOUT_H);
//Print Accelerometer Values
printf("Accelerometer:\n X:%d\n Y:%d\n Z:%d\n ", Accel_X, Accel_Y, Accel_Z);
//Print Gyroscope Values
printf("Gyroscope:\n X:%d\n Y:%d\n Z:%d\n ", Gyro_X, Gyro_Y,Gyro_Z);
//Sample Readings every second
return MRAA_SUCCESS;
mraa_init();
mraa_i2c_context mpu9150_i2c;
mpu9150_i2c = mraa_i2c_init(1);
if (mpu9150_i2c == NULL)
printf("MPU9150 I2C initialization failed, exit...\n");
exit(1);
printf("MPU9150 I2C initialized successfully\n");
mraa_i2c_address(mpu9150_i2c, MPU_ADDR);
printf("MPU9150 I2C Address set to 0x%x\n", MPU_ADDR);
//Reset all the Registers
MPU9150_I2C_Write(PWR_MGMT_1, PWR_RESET);
printf("MPU9150 Reset\n");
MPU9150_I2C_Write(PWR_MGMT_1, DEVICE_ON);
printf("MPU9150 Switched ON&#92...
Sergio_A_Intel
Are you powering the MPU-9150 correctly, according to the hookup guide Vcc is between 2.375V and 3.465V.
Also, how are you connecting the sensor to your board? Have you installed the library from https://github.com/sparkfun/MPU-9150_Breakout sparkfun/MPU-9150_Breakout · GitHub ? What Arduino IDE version are you using?
In https://learn.sparkfun.com/tutorials/mpu-9150-hookup-guide?_ga=1.9180917.1313332447.1447083068# installing-the-arduino-library MPU-9150 Hookup Guide - learn.sparkfun.com there is a section to run an example from that library. Run it to see if the library was properly installed.
Sergio
FPhil
Hi Sergio,
I finally figured out the problem. The I2C bus was declared as a random pointer which produced a segmentation fault when it became NULL.
Thanks!
