Community
cancel
Showing results for
Search instead for
Did you mean:
TElli3
What a silly python question
I am trying to code using python on the Edison (from the IOT XDK).
I can run the classic "hello World" using python from the command line; however I cannot make it work from within a script. I know it seems simple to most but I am pulling my hair out.
Here is my script file:
main.py
# !/usr/bin/python
print("Python running on Edison")
I get the following after saving and downloading to Edison:
| Intel (R) IoT - NPM Install - (may take several minutes)
npm WARN package.json SimpleTest@0.0.0 No description
npm WARN package.json SimpleTest@0.0.0 No repository field.
npm WARN package.json SimpleTest@0.0.0 No README data
| NPM INSTALL COMPLETE![ 0 ] [ 0 ]
Intel XDK - Message Received: run
=> Stopping App <=
ERROR: /home/root/.node_app_slot/main.py:2
ERROR: print("Python running on Edison")
ERROR: ^
ERROR: ReferenceError: print is not defined
at Object. (/home/root/.node_app_slot/main.py:2:1)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
at startup (node.js:119:16)
at node.js:935:3
I get the feeling that I am not really executing the script with python, but have no idea. If I insert a comment line (# ) as the second line, that line show up with the error.
Any help would be appreciated.
Tags (1)
Matthias_H_Intel
hard to say what you do without knowing exactly what you do.
  • how did you try to start the python program?
    • within XDK? If yes, how?
    • trying to run as a Node.JS app?
  • if you set your script executable (chmod +x main.py) and run it from console (./main.py) it will work just fine
TElli3
Thank you Mahan and Diego,
I am using the IOT XDK and yes, I did try to run the python script from the XDK interface. This is the way I have ben testing my node.js scripts and all seems to work when I do this. I was under the impression that I could create code for any of the supported languages (including python) and execute them the same way during debugging.
I do not understand all of the additional detail after the "ReferenceError", but I suppose it is trying to tell me exactly where the command failed.
I mentioned that the error seems to indicate that an interpreter other than python is looking at the script. Just my feeling since it is such a simple script. I thought that the hashbang (line 1) code was supposed to tell the system which interpreter to use on the script. I still seem to be misunderstanding something if the XDK cannot run this script.
I really only selected python to use as I have seen various code snippits that deal with Bluetooth using python to automate device selection.
Thanks again fro your quick responses,
Ted
Matthias_H_Intel
while you obviously can run Python code from the XDK ssh console for the target system the IDE itself IMHO is only supporting Javascript (Node.JS resp) [besides CSS / HTML].
But you surely can run your Python scripts on the target and communicate with XDK Node.JS code
Diego_V_Intel
You can also run the Python script using the following command:
Diego.
