I thought that the new board would just boot up with my old microSD card.(Yocto Jun9 2015 image)!
but I got this error instead:
ASSERT_EFI_ERROR (Status = Aborted)
***** ERROR: System boot failure!!!!!!! *****
***** - Press 'R' if you wish to force system recovery *****
***** (connect USB key with recovery module first) *****
***** - Press any other key to attempt another boot *****
Recovery boot selected..........
New boot attempt selected........
it seems your new board is bricked.
Probably these links will help:
https://communities.intel.com/thread/58659 https://communities.intel.com/thread/58659
https://communities.intel.com/thread/97375 https://communities.intel.com/thread/97375
BR,
xbolshe
Thanks for the links.
This morning when I tried to boot the Galileo it came up with my microSD inserted.
Friday the last thing I did was to try to run Arduino sketches, but without luck and I had to stop.
Could it be the case that the Arduino IDE upgraded the firmware and fixed the problem?
Anyway happy that it is working again.
Hi JaddeDragon,
Did you upgrade the firmware in the new Galileo so that both Galileo have the same fimware version?
Just curious: does the new Galileo boot without the SD card?
Fernando.
Thanks for your reply.
Well, I don't remember in detail what I did Friday evening. But I did ran some sketches that did not work, and I tried to install upgrades.
Don't know why, but everything works now. .
What command to I use to see the firmware version on my system? Do you refer to BSP version?
Hi JadeDragon,
Good to know your Galileo is working, hard to know why, though.
The Intel Galileo Firmware Updater shows the "Current Board Firmware", I don't know about BSP version, I think it's closely related, but I'm not completely sure about...
HTH,
Fernando.
Replying to myself just to mention that DiegoV_Intel posted in another thread:
Also, check the output of the following command: cat /sys/firmware/board_data/flash_version. We can check the firmware version with that command. For the firmware version 1.0.4, the output should be 0x01000400.
