Community
cancel
Showing results for
Search instead for
Did you mean:
TKris2
What debugger to use with an Intel D2000 MCU?
Jump to solution
I'm new to the Intel Quark MCUs, but I'd like to give them a try. I see that the D2000 has a JTAG interface, but there is no specific debugger or programmer device offered. Does this mean that the D2000 will work with any device that supports JTAG? I also took a look at the CRB which has an FT232H from FTDI as a JTAG/USB interface. Is that all that is needed to work with the D2000? If I create a similar design on a custom PCB, will Intel's IDE be able to connect to the MCU through the FTDI device?
Thanks in advance for your answers!
Michelle_C_Intel
Hi timur.kristof
The OpenOCD debugger is provided in the Intel System Studio for Microcontrollers 2016 Toolchain available for download at - https://registrationcenter.intel.com/en/forms/?productid=2580 Commercial Product Request - Intel® Products
And yes the FTDI should be all you need to connect the ISSM to your board.
regards,
Michelle.
Michelle_C_Intel
Hi timur.kristof
regards,
Michelle.
TKris2
Thank you Michelle for your answer!
