Intel® Makers
9881 Discussions
What defconfig used by kernel in 3.0 sources?
nSrob
Hi. Can someone explain what defconfig used for kernel building? Thanks.
/yocto/iot-devkit-yp-poky-edison-20160315/build_edison$ find ../../iot-devkit-yp-poky-edison-20160315/ -name defconfig../../iot-devkit-yp-poky-edison-20160315/poky/scripts/lib/bsp/substrate/target/arch/common/recipes-kernel/linux/{{ if kernel_choice == "custom": }} linux-yocto-custom/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/wpa_supplicant/wpa-supplicant/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/hostapd/files/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-yocto/recipes-core/busybox/busybox/poky-tiny/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/um/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/h8300/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/frv/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/linux-kernel/arch/s390/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-intel-iot-devkit/recipes-core/busybox/busybox/iot-devkit-spi/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-intel-iot-devkit/recipes-core/busybox/busybox/iot-devkit/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta/recipes-core/busybox/busybox/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta/recipes-connectivity/wpa-supplicant/wpa-supplicant/defconfig
../../iot-devkit-yp-poky-edison-20160315/poky/meta-openembedded/meta-oe/recipes-connectivity/hostapd/hostapd-2.2/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/i686-linux/qemu-native/2.1.0-r0/qemu-2.1.0/roms/openbios/arch/x86/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/i686-linux/qemu-native/2.1.0-r0/qemu-2.1.0/roms/openbios/arch/ia64/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/i686-linux/qemu-native/2.1.0-r0/qemu-2.1.0/roms/openbios/arch/ppc/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/i686-linux/qemu-native/2.1.0-r0/qemu-2.1.0/roms/openbios/arch/amd64/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/hostapd-daemon/2.1-r0/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/hostapd-daemon/2.1-r0/hostapd-2.1/hostapd/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/wpa-supplicant/android-4.4.4_r2.0.1-r1/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/wpa-supplicant/android-4.4.4_r2.0.1-r1/git/wpa_supplicant/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/wpa-supplicant/android-4.4.4_r2.0.1-r1/git/hostapd/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/linux-libc-headers/3.16-r0/linux-3.16/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/linux-libc-headers/3.16-r0/linux-3.16/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/linux-libc-headers/3.16-r0/linux-3.16/arch/frv/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/linux-libc-headers/3.16-r0/linux-3.16/arch/s390/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/core2-32-poky-linux/busybox/1.22.1-r32/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/include/config/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/um/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/h8300/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/frv/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/packages-split/kernel-dev/usr/src/kernel/arch/s390/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/include/config/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/um/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/h8300/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/frv/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/package/usr/src/kernel/arch/s390/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/include/config/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/include/config/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/um/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/h8300/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/frv/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/sysroot-destdir/usr/src/kernel/arch/s390/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/include/config/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/arch/arm64/configs/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/arch/alpha/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/arch/um/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/arch/h8300/defconfig
../../iot-devkit-yp-poky-edison-20160315/build_edison/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/image/usr/src/kernel/arc...
FIvan
It should be poky/linux-kernel/arch/x86/configs/i386_edison_defconfig
But sometimes it's copied to .config and then it's overwritten by another config.
FIvan
FIvan
You may need to change the version variable PR in
poky/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-externalsrc.bb
Then it'll restart the configuration process.
