Intel® Makers
9881 Discussions
What does PIN 32_F1 function on Quark D2000 schematics?? what does battmon 1.8v mean???
prao
Given in the schematics what does the pin 32 perform ...Also where is the path for AR in schematics pin 1.
Sergio_A_Intel
Pin 32 is a functional pin that can be configured as a GPIO or as SPI Master Interface. If you look at Table 3 of the D2000 datasheet you'll see that pin 32 is a GPIO that is powered with IOVDD/AVDD.
See more information on AVDD and IOVDD here:
You can also select one of the following functions for pin 32:
Function 0: GPIO 1
Function 1: AI1
Function 2: SPI_M_SS1
Pin 1 (AR) is also described in table 3. It is a pin that needs to be powered with AVDD. It's a power source pin.
D2000 datasheet: http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/quark-d2000-datasheet.html http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/quark-d2000-datasheet.html
Sergio
Sergio_A_Intel
Function 0: GPIO 1
Function 1: AI1
Sergio
