My environment:
Edison/Linux version: 201603141535
Windows 10
Windows sees a drive named Edison with a size of 766 MB
Edison/Linux sees /media/storage of 785 MB (close enough)
Looking here: http://download.intel.com/support/edison/sb/edison101presentationfromidfforthecommunity.pdf
it says: Flash Storage 4 GB eMMC
I am assuming that /media/storage and the Edison disk are the SAME as Flash Storage.
Question: With the my March 2016 version of Yocto, was a change made so that 4GB is no longer used for /media/storage, i.e. for the Edison disk space that shows up on Windows?
Hi Bill,
Thanks for your interest in the Intel Edison Platform.
This is a good question. The drive named Edison which is 766 MB, was a storage dedicated to flash the image in previous versions. Now this space is not used, the Yocto image is flashed in the 4 GB eMMC. I hope you find this information useful.
I will be waiting for your reply, have a nice day.
-Jose.
Hi Hose.
Thanks for the quick response.
Question: Is that 4 GB of eMMC visible to me when I login to Edison/Yocto? i.e. can I do something with it from the Yocto side.
Bill
Hi Bill,
Yes you can do something with it, for example if you are using the console, you can create a file using this command: touch new.txt. You will create a text file and it will be store in the 4GB. May I ask what are trying to do with this storage space?
I will be waiting for your reply, we hope you have a nice day!
-Jose.
Jose,
Thanks for the QUICKER response.
Regarding : "May I ask what are trying to do with this storage space?"
I am just playing with Edison and trying to understand lots of things. I am working through all the various samples projects and asking questions like this one and others.
Assuming the following:
The Windows Edison space of 766M is part of the eMMC4 GB space
On Linux that same SPACE is /media/storage which is mounted on /dev/loop0
Question: what is the file system for the eMMC 4GB that I would cd to and then do the touch new.txt
Bill
Hi Bill,
It is not necessary to access any storage file. Once you have access the Linux console, any file that you create in any directory, will be save in the 4GB eMMC. Below I attach you an example creating a file.
I'll be waiting for your reply, have a nice day.
-Jose.
Hi Jose,
This is very interesting!
Windows, Linux and Mac PCs have a hard disk, I'll call it disk0, which is where the OS is installed and where people install programs and place their data.
I see Edison as
another PC but with a different set of inputs and outputs compared to a Windows PC,
and it's disk0 is the 4GB of eMMC
The following two sets of text are from df command output, the second one is sorted.
root@edison:~# df
Filesystem 1K-blocks Used Available Use% Mounted on/dev/root 1444528 980812 373236 73% /
devtmpfs 491264 0 491264 0% /dev
tmpfs 491548 0 491548 0% /dev/shm
tmpfs 491548 596 490952 1% /run
tmpfs 491548 0 491548 0% /sys/fs/cgroup
tmpfs 491548 4 491544 1% /tmp
/dev/mmcblk0p10 1337936 2100 1319452 1% /home
tmpfs 491548 6164 485384 2% /var/volatile
/dev/mmcblk0p5 1003 19 913 3% /factory
/dev/mmcblk1p1 15549952 96 15549856 1% /media/sdcard
tmpfs 98312 0 98312 0% /run/user/0
/dev/loop0 784872 80 784792 1% /media/storage
root@edison:~#
root@edison:~# df | sort
Filesystem 1K-blocks Used Available Use% Mounted on/dev/loop0 784872 80 784792 1% /media/storage
root@edison:~#
Question: do all the filesystems that begin with /dev reside on the eMMC disk0?
Question: are all of the NON /dev/filesystems created by Yocto in the 4GB of memory?
Bill
Hi Bill,
All the partitions you see using the command df, are done after you flash the image. The space that can be used is the one shown in /dev/root (1.4G). If you will like to increase the size of the root partition, I would recommend to follow this thread ( ). I hope you find this information useful.
Have a nice day.
-Jose.
Jose,
Thanks for the pointer.I am not at the point where I need to increase the size of /dev/root.
This was educational. Thanks for helping.
I am done.
Bill
Hi Bill,
Always happy to help, if you have any more questions please don't hesitate to contact us.
Have a nice day!
-Jose.
