Intel® Makers
9881 Discussions
What versions of SD cards are compatible with this board?
ARami7
There are fast SD cards that can boot the OS really fast, as much as there are cheaper/slower alternatives, i dont know if the new fast SD cards will be compatible with this board, is there a list of compatible SD cards for this board?
Diego_V_Intel
Hi AdanChristo,
I haven't had issues with the SD cards I've used so far. According to this document: https://www-ssl.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006045.h... Product Brief for Intel® Galileo Gen 2 Development Boards, the only requirement specified for the SD card is that it has to be up to 32GB. Unfortunately, there isn't a list of compatible SD cards that I can recommend you, so I would say that the only way to know if the SD card you are talking about works would be testing it.
Just to let you know, currently I use a microSDHC 8GB Class 4 card.
Diego
FTinetti
Honored Contributor I
Hi AdanChristo,
I don't remember to have seen any reference to specific SD card speed requirement/s or suggestions at Intel site/s.
I've seen suggestions to use class 10 cards in other -non Intel- sites (https://projects.wyliodrin.com/wiki/boards_setup/arduinogalileo https://projects.wyliodrin.com/wiki/boards_setup/arduinogalileo) or in some posts
HTH,
Fernando.
Diego_V_Intel
Hi AdanChristo,
Diego
