Intel® Makers
9868 Discussions
Where can I get information on the Joule antennas?
Community Manager
I would like to know how close can Joule's antennas be placed to metal structures like ground planes in a PCB.
FGold
New Contributor II
And or any planes.
Also any specification for antenna: mounting, positioning, power, electrical characteristic, alternative antenna recommendations, ...
Here is what I found:
Regulatory Information for Intel® Joule™ Compute Module
http://www.intel.com/content/www/us/en/support/boards-and-kits/000022313.html Regulatory Information for Intel® Joule™ Compute Module
Community Manager
Hi Hamco,
Thank you for your interest in the Joule platform.
All information about antennas can be found in the document floydg just provided, http://www.intel.com/content/www/us/en/support/boards-and-kits/000022313.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000022313.html. Did you check that before?
Floydg, I'm a bit confused by your post, I'm not sure if you have a question about the Antenna use on Joule too. Is this the case?
-Pablo
FGold
New Contributor II
Please point out where your answer addresses the concerns regarding ground planes or other planes on a PCB.
Community Manager
The doc you linked to explains WiFi from a user safety point of view. I wanted to know how close to metal structures like a PCB ground or power plane if the antenna is placed on the PCB without reducing the antenna reception gain.
Community Manager
Hi guys,
Let me investigate this a little bit more. We appreciate your patience in the meantime.
-Pablo
Community Manager
Hi guys,
Thank you for your patience, we want to let you know that we already have some more information.
This is the link to the Joule antenna's website http://www.taoglas.com/product/freedom-fxp830-2-44-9-6-0ghz-flexible-pcb-antenna-ipex-mhf4/ http://www.taoglas.com/product/freedom-fxp830-2-44-9-6-0ghz-flexible-pcb-antenna-ipex-mhf4/. In general, the antenna should be placed as far away from metal as possible. Metal planes, including PCB ground planes will reduce RF performance.
Power and electrical characteristics should not exceed limits listed in Table-1 of the following link http://www.intel.com/content/www/us/en/support/boards-and-kits/000022313.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000022313.html.
Regarding the antenna mounting and positioning, it is strongly dependent on system design and usage.
In section 7.1 of the Edison Module Hardware Guide, http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf, it is defined the keep-out zone for the PCB mounted chip antenna, Joule doesn't have a PCB mounted chip antenna. So we suggest to follow the recommendations of the antenna vendor if placing a chip antenna on a customer carrier board.
-Pablo
