Intel® Makers
9873 Discussions
Who can help me to translate Arduino I2C code to mraa I2C code.
HLiu37
I am confusing about my arduino I2C code, because I want to change it to mraa I2C code. I am not familiar with mraa I2C function. I just want to connect and communicate with my atmega8 chip. Because I want to read the analog sensor value. The following is the arduino code.
Wire.begin();
Wire.beginTransmission(4);
Wire.write(0x55);
Wire.write(0xaa);
Wire.write(cmd);
Wire.write(value);
Wire.write((unsigned char)(0x55+0xaa+cmd+value));
Wire.endTransmission();
I don't know what the appropriate mraa code is. I hope someone who can help me. I will really appreciate him.
Carlos_M_Intel
Hi ToneLiu,
Take a look at the http://iotdk.intel.com/docs/master/mraa/ mraa: Main Page, you will see in there all the functions and features of the library. You could see thehttp://iotdk.intel.com/docs/master/mraa/i2c_8h.html i2c.h File Reference and http://iotdk.intel.com/docs/master/mraa/classmraa_1_1_i2c.html I2c Class Reference
In this website: https://github.com/intel-iot-devkit/mraa/tree/master/examples mraa/examples at master · intel-iot-devkit/mraa · GitHub you will see some examples with MRAA, I think it will be very helpful for you.
In order to translate the functions you want to use, it will depend on the language you are going to use, as you may know with the MRAA library you can use Javascript, Java, Python, C or C++.
Charlie
Carlos_M_Intel
Hi ToneLiu,
Charlie
WDobr
I am working with Romeo for Intel® Edison Controller (With Intel® Edison). On this board there is integral motor driver L298P.
I am running motors with library https://github.com/ouki-wang/remeo4edison ouki-wang/remeo4edison - C++ - GitHub with success.
I was trying to run it in same way as in this library but it does not work. Can someone suggest me what is wrong with my code ?
I want to run motor1 with max speed 255
# include
void setup() {
Wire.begin();
Wire.write(0x55);
Wire.write(0xaa);
Wire.write(0xc1);
Wire.write(0xff);
Wire.write((unsigned char)(0x55+0xaa+0xc1+0xff));
void loop() {
Carlos_M_Intel
Hi wdobrzyc,
Have you tried with the example on: http://www.dfrobot.com/wiki/index.php/RoMeo_BLE_(SKU:DFR0305)# Speed_regulation_of_the_two-armature_DC_motor RoMeo BLE (SKU:DFR0305) - Robot Wiki
In the switch module you will see the function advance (255,255) that should allow you to use the max speed.
Charlie
