Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Why Galileo Gen2 can't use the IRremote library downloadeded from Github
Jump to solution
I want to make a IR controller after i saw a demo in Arduino Chinese Community.Then i try to learn it. but a fatal error occurred that i can't use the library because of the IDE i'm using is for Galileo Gen2.please help me fix this, Ths.
Tags (1)
Accepted Solutions
Highlighted
Hi LouisWei,
We are moving your post to the appropriate place. About your question could you specify which github library you are using? You can also check AllynH's project /thread/51413 https://communities.intel.com/thread/51413 , it might give you a couple of ideas for yours. I hope you find it helpful.
JPMontero_Intel
Highlighted
Hi LouisWei,
JPMontero_Intel
