Intel® Makers
9881 Discussions
Why does XDK doesn't recognize Intel Galileo board?
TLima2
I'm trying to connect my Galileo's board to the internet to send commands and receive sensor's data. First, I want to create a basic connection, then, utilize MQTT Protocol to send and recive data.For this, I am using this book: Intel Galileo Blueprints - Marco Schwartz. In Chapter 4, the author says to install XDK IoT version and install a linux iso on a micro SD. I followed this tutorial: https://software.intel.com/fr-fr/programming-blank-sd-card-with-yocto-linux-image-windows https://software.intel.com/fr-fr/programming-blank-sd-card-with-yocto-linux-image-windows, then: https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows# terminal https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows# terminal and finally: https://software.intel.com/en-us/getting-started-with-the-intel-xdk-iot-edition https://software.intel.com/en-us/getting-started-with-the-intel-xdk-iot-edition, including installing all the softwares required. However, when I connect the Galileo's board with an ethernet cable, as the micro SD with Linux Iso, XDK doesn't recognize it. I tried automatic search, and doesn't recognize it, tried to enter the IP address manually, and doesn't recognized it. I Would like to know what is going on, why can't recognize.
Sergio_A_Intel
When you followed the last tutorial did you get the connection established message? Do you see an IP address in the eth0 interface? Type ifconfig for more information. When you tried the manual connection what IP and port you used? What user name and what password? Do you have a password set on the Galileo?
Take a look at and make sure you already tried all the suggestions
Sergio
Sergio_A_Intel
Have you followed the suggestion of the previous post? Were you able to work with the XDK and the Galileo?
Sergio
