Intel® Makers
9873 Discussions
Wi-Fi / SSH Setup Issue on Windows 10 Pro 64-bit
BBenH
Issue:
I am attempting to run the setup of the Intel Edison on a Windows 10 Pro 64-bit machine. I am using the "intel_edison_setup_win_v2016.2.007" installer. I run into an issue where I cannot set the device name or connect to Wi-Fi.
Hardware:
- Intel® Edison compute module
- Arduino* expansion board
Details:
When on the "Options" section of the installer I am able to install the USB drivers and firmware for the Edison. When setting up SSH I get an error when going to change the device name, "Can't change the device name". I have attached screenshots for reference. It also cannot find any Wi-Fi networks and I am easily within range of many.
Issue setting up SSH and Wi-Fi via Intel Edison Installer (intel_edison_setup_win_v2016.2.007)
Error message displayed "Can't change the device name." when attempting to set the device name and password.
What I've tried:
- Going through the setup steps here: https://software.intel.com/en-us/get-started-edison-windows IoT - Get Started with the Intel® Edison Development Board on Windows* 64-bit | Intel® Software
- Re-setting device and attempting additional install using re-downloaded setup files
- Removing USB drivers and re-installing
- Re-flashing the firmware
- Re-seating Edison chip
- Making sure to use both external power and USB (along with all combinations of this)
- Reset PC and attempted to re-install
Any help is much appreciated! I am hoping that it is something extremely simple that I just missed.
BBenH
Work around solution:
I was not able to solve the Intel setup issue but I was able to find a work around . I downloaded the Intel XDK and then used the serial terminal in that to setup the Wi-Fi and SSH. Below is the commands I used:
configure_edison --setup
I then went through the options and named the device and connected it to my wireless network. Worked like a charm and I can now access the device wirelessly.
I know that this may not be the best solution for some so please feel free to post a reply!
BBenH
Community Manager
Hi bkhayes99,
Yes the solution is right how you provided it. Besides the Edison Configuration Tool, you can setup the Wi-Fi manually, as it is described in this guide: https://software.intel.com/en-us/node/628264.
About the serial terminal in Intel XDK it is not necessary and you can use any serial terminal like PuTTY (follow this guide https://software.intel.com/en-us/setting-up-serial-terminal-on-system-with-windows). Once you are connected to the serial port just use the command: configure_edison --setup
-Leonardo
Community Manager
Hi bkhayes99,
Do you have another issue with the Wi-Fi/SSH setup of the Intel Edison? Is everything fine? If something else happens let us know, we're here to help you.
-Leonardo
