Intel® Makers
9882 Discussions
Wi-Fi module ESP8266 in Galileo
FTinetti
Honored Contributor I
It is not possible to use the Galileo Arduino IDE Monitor as a direct way of communication with ESP8266 because the Galileo Arduino IDE monitor is not related to Galileo's pins 0 & 1 ( , ). However, that's the reason we do not need anything else in Galileo to work on pre-configured 115200 bauds ESP8266 modules (i.e. no extra hardware and no SoftwareSerial library). Adapting the code from http://allaboutee.com/2014/12/30/esp8266-and-arduino-webserver/ http://allaboutee.com/2014/12/30/esp8266-and-arduino-webserver/ I had in the serial monitor:
AT+RST
OK
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
ó (some junk)
n't use rtc mem data
r Ž 'rl€Ì÷
Ai-Thinker Technology Co.,Ltd.
ready
AT+CWMODE=2
OK
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"5e:cf:7f:11:da:0c"
OK
AT+CIPMUX=1
OK
AT+CIPSERVER=1,80
OK
And after connecting the "new" available WiFi (AI-THINKER_11DA0C in my case) from my laptop
I opened the web browser and:
In the meantime, in the serial monitor:
,285:GET / HTTP/1.1
Host: 192.168.4.1
User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64; rv:37.0) Gecko/20100101 Firefox/37.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip,AT+CIPSEND=0,50
OK
Recv 50 bytes
SEND OK
AT+CIPSEND=0,21
OK
Recv 21 bytes
SEND OK
AT+CIPCLOSE=0
0,CLOSED
OK
So everything is "up & running".
BR,
Fernando.
