WIll any WiFi USB dongle work with the Intel Galileo Gen 1/2?
Will this one work for example?
http://www.newark.com/element14/wipi/wlan-module-for-the-raspberry/dp/07W8938?ost=wifi+raspberry&sel... WIPI - ELEMENT14 - WLAN MODULE FOR THE RASPBERRY PI | Newark element14
- Tags:
- USB General
- WiFi
Hi BrechtW
I haven't seen project with galileo using that specific dongle. I suggest you to first check the drivers/modules/packages required for any dongle you may want to buy in order to be sure that is available for the kernel and yocto version in the Galileo.
Take a look at this thread: It may be helpful for you.
Charlie
Is there a USB Wifi Dongle that is conformed working with the Galileo Gen 2?
Hi BrechtW,
There isn't an official list of dongles that have been tested with the Galileo Board. I suggest you to look into the drivers required for the dongle in order to enable them in the image.
I suggest you to check the following threads:
Charlie
