Community
cancel
Showing results for
Search instead for
Did you mean:
Wifi Bandwidth
Jump to solution
What is the bandwidth of the Edison's wifi module?
I want to return data over wifi when running a program on the Edison.
Tags (1)
Accepted Solutions
Hello dunex_1,
As you can see in the http://www.intel.com/support/edison/sb/CS-035274.htm Edison's Hardware Guide in section 3.2, the Edison's Wi-Fi/Bluetooth module complies with IEEE's standard 802.11 with integrated dual-band (2.4 / 5 GHz). If you would like to learn more about this standard I'd suggest you to check https://en.wikipedia.org/wiki/IEEE_802.11 IEEE 802.11 - Wikipedia, the free encyclopedia, you can also learn more about the Edison's Wi-Fi/Bluetooth module in https://www.broadcom.com/products/wireless-connectivity/bluetooth/bcm43341 https://www.broadcom.com/products/wireless-connectivity/bluetooth/bcm43341.
Peter.
Hello dunex_1,
Peter.
Intel_Peter,
Thank you. I really appreciate it. I found what I was looking for from one of the links.
