Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Wifi p2p connection
I've been working on getting a P2P connection up for some time. I'd like to recompile the kernel with p2p commands accessible through wpa_cli which I think is realistic. I believe that I have to add:
CONFIG_CTRL_IFACE=y
CONFIG_P2P=y
CONFIG_AP=y
CONFIG_WPS=y
to defconfig. If this is correct can I get a pointer to which one as I change it in several defconfig's before the bitbake command. It was my understanding that defines in defconfig are equivalent to individual package .config (which I should be putting these in wpa_cli's .config). Is this correct?
Is there a way through
bitbake linux-yocto -c menuconfig
I see the mac80211 mesh networking support under networking support > Wireless
Jeff
Tags (1)
Highlighted
Re: Wifi p2p connection
Hi Maaaah,
I've not done this procedure before but I believe those are the correct options. I'm not sure if you can change those options on the defconfig directly, I believe you have to do it using the menuconfig option. Regarding the package, any changes made to these files has to be done at a kernel level and will not affect the package itself.
Sergio
Highlighted
latest Edison beta image just released seems to support WiFi direct. Maybe give it a try?
Highlighted
Flashed the new image and going through the steps. Hopefully I'll have a detailed breakdown on getting Edison to handshake with the Wifi p2p android sdk application posted back to the forum soon.
Highlighted
There's still problems. Has anyone been able to get wifi p2p to work with Edison? With the new image flashed this is what I get
# Turn off wpa_supplicant that comes up on boot to connect to my AP
> killall wpa_supplicant
> wpa_supplicant -I wlan0 -c /etc/wpa_supplicant/p2p_supplicant.conf -Dnl80211 &
> wpa_cli
now in wpa_cli
(Search for devices on Android > Settings > Wifi > Wifi Direct)
> p2p_find
<3>P2P-DEVICE-FOUND XX:XX:XX:XX:XX:XX p2p_dev_addr=XX:XX:XX:XX:XX:XX pri_dev_type=10-0050F204-5 name='Trellabs3' config_methods=0x188 dev_capab=0x24 group_capab=0x0
> p2p_connect XX:XX:XX:XX:XX:XX pbc go_intent=0
P2P-FIND-STOPPED
OK
<3>P2P-FIND-STOPPED
(Android comes up with a connect to DeviceName prompt and Peer Devices > DeviceName switches to Invited)
(The about 30 seconds later)
> > P2P-GO-NEG-FAILURE status=-1
<3>P2P-GO-NEG-FAILURE status=-1
P2P-DEVICE-LOST p2p_dev_addr=XX:XX:XX:XX:XX:XX
<3>P2P-DEVICE-LOST p2p_dev_addr=XX:XX:XX:XX:XX:XX
connecting through pin, go_intent=7 or go_intent=15 still doesn't change the GO-NEG failure. Using p2p_group_add before hand does not change this behaviour either. I seem to remember on TI's CC3200 there was a way to force the Group Owner Negotiation, they're different beasts of course, is there a way to skip this step?
Jeff
Highlighted
That feature was just implemented in R2. The doc describing it is at:
Let me know if you still have issues with getting it to work, and we'll debug from there.
Highlighted
Hi MPayne, yes the document is correct for setting up a connection with Android's OS. I'll be checking the SDK example too shortly. Here's the short walkthrough (while in depth is provided by Intel: )
All these commands will be from Edison
> reboot
> systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant service
Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled)
Active: active (running) since Mon 2015-02-09 18:09:19 UTC; 7min ago
Process: 276 ExecStartPost=/bin/systemctl start wpa_supplicant_p2p_event (code=exited, status=0/SUCCESS)
Process: 210 ExecStartPost=/bin/systemctl start wpa_supplicant_wlan0_event (code=exited, status=0/SUCCESS)
Main PID: 209 (wpa_supplicant)
CGroup: /system.slice/wpa_supplicant.service
└─209 /usr/sbin/wpa_supplicant -u -c/etc/wpa_supplicant/wpa_suppli...
Feb 09 18:09:19 Vitaliti002 systemd[1]: Started WPA supplicant service.
> wpa_cli -iwlan0 interface
Available interfaces:
p2p-dev-wlan0
wlan0
# click search for devices on Wi-Fi Direct tab on Phone
> wpa_cli -ip2p-dev-wlan0 p2p_find
OK
> wpa_cli -ip2p-dev-wlan0 p2p_peers
a2:0b:ba:c6:ba:a9
> wpa_cli -ip2p-dev-wlan0 p2p_peer a2:0b:ba:c6:ba:a9
a2:0b:ba:c6:ba:a9
device_name=Trellabs3
manufacturer=
model_name=
model_number=
serial_number=
dev_capab=0x24
group_capab=0x0
level=-33
age=0
listen_freq=2412
wps_method=not-ready
interface_addr=00:00:00:00:00:00
member_in_go_dev=00:00:00:00:00:00
member_in_go_iface=00:00:00:00:00:00
go_neg_req_sent=0
go_state=unknown
dialog_token=0
intended_addr=00:00:00:00:00:00
country=XX
oper_freq
req_config_methods=0x0
flags=[REPORTED]
status=0
wait_count=0
invitation_reqs=0
> wpa_cli -ip2p-dev-wlan0 p2p_connect a2:0b:ba:c6:ba:a9 pbc persistent go_intent=15
OK
# Click pop up on phone to get to Connected
> wpa_cli -ip2p-dev-wlan0 interface
p2p-wlan0-1
p2p-dev-wlan0
wlan0
> reboot
# It doesn't automatically reconnect on login, on start-up in the future I'll use
> wpa_cli -ip2p-dev-wlan0 p2p_listen
Highlighted
So just to be sure - you've moved past the initial blocking issue you had? Do you need additional clarification?
Highlighted
Yep, the document and the new release got me up and connecting.
j
