Community
cancel
Showing results for
Search instead for
Did you mean:
DPose
New Contributor II
Wifi set to autoconnect but doesn't
Jump to solution
Hey mhahn et. al., I'm having issues getting wifi to autoconnect in multiple configs/environments. I have good settings I think:
root@Garviel:~# cat /var/lib/connman/wifi_685d43256912_4d794c6974746c6552656454726163746f72_managed_psk/settings
[wifi_685d43256912_4d794c6974746c6552656454726163746f72_managed_psk]
Name=
SSID=4d794c6974746c6552656454726163746f72
Frequency=2412
Favorite=true
AutoConnect=true
Modified=2015-11-01T01:48:57.431143Z
Passphrase=
IPv4.method=dhcp
IPv4.DHCP.LastAddress=192.168.0.155
IPv6.method=auto
IPv6.privacy=disabled
IPv6.DHCP.DUID=000100011d558608685d43256912
Failure=connect-failed
But it will not connect automajikly. I can connect manually but after a bit the wifi drops. Hardware is this:
01:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4)
Same issue essentially on another target in a different lab with an open network:
root@galileo:~# cat /var/lib/connman/wifi_6480991c6a78_6a6c656e67656c_managed_none/settings
[wifi_6480991c6a78_6a6c656e67656c_managed_none]
Name=
SSID=6a6c656e67656c
Frequency=2462
Favorite=true
AutoConnect=true
Modified=2015-11-01T01:17:28.061899Z
IPv4.method=dhcp
IPv6.method=auto
IPv4.DHCP.LastAddress=192.168.1.142
with this hardware:
01:00.0 Network controller: Intel Corporation Centrino Advanced-N + WiMAX 6250 [Kilmer Peak] (rev 5e)
Same behavior. Any help very much appreciated!!
Dallas
Matthias_H_Intel
xthunderheartx - not sure I can answer. Some hints:
the auto-connect is temporarily ignored in connman if there is some lower level disconnect or connection failure error. This way connman will not try to re-connect to AP that is constantly failing.
User is able to manually re-connect the AP and if the connection succeeds, then auto-connect is enabled again.
Matthias_H_Intel
DPose
New Contributor II
Are you kiddin'? That absolutely answers the question! That has to be what is happening. Of course it brings up another question which is can connman's behavior be changed to always try to autoconnect. In our application the Galileo has now wired Ethernet (the RJ45 is literally removed), no console (we use ttys1 to talk to a PIC, ttyS0 to talk to a modem) and lives in an unattended environment. Manual intervention is not really an option.
While I have you can you tell me if there is a new image for IOTDK image in the works? I notice there is a 2.0 repo on the site but the released image is 1.5 right? I have been hoping for some package upgrades, though it looks like most at still at the 1.5 versions. Connman is one I was hoping for as I couldn't get Wifi Direct (p2p) working and have to resort to plain old tethering. Plus you tell people on other channels like irc:# connman you are running 1.25 and their immediate response is "upgrade".
Thanks for your help Matthias!
