Intel® Makers
9872 Discussions
Will Dameware allow remote connections to an Intel Compute Stick?
BRutl1
Thinking of using a compute stick at a remote location. Can I use the Dameware utility to establish a remote connection with windows?
Community Manager
Hello Inyo55:
In regard to your question, I looked on the web site that belongs to Dameware and I found the requirements for the utility and it should work just fine with the stick, on the following link you will be able to see that information, please choose where it says Tech Specs:
http://www.dameware.com/remote-support-software http://www.dameware.com/remote-support-software
And on the following link you will be able to confirm that all the sticks comply with those requirements:
http://ark.intel.com/compare/86612,86613,91065,91064,91979,91980,91981 http://ark.intel.com/compare/86612,86613,91065,91064,91979,91980,91981
Also, on the link above you will be able to get a free trial of that application.
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Alberto
