I'm using WR Linux 7 on a Galileo Gen 2 board. I can't seem to get Galileo-IO/MRAA package to install on my platform.
I install the package:
root@147:~# npm install galileo-io
/> galileo-io@0.9.4 postinstall /root/node_modules/galileo-io> node scripts/postinstallgalileo-io@0.9.4 node_modules/galileo-io
├── remapped@0.2.1 (getobject@0.1.0, traverse@0.6.6)
└── es6-shim@0.34.4
But I receive and error when trying to run any code JS code that requires the package:
Error: Cannot find module 'galileo-io'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/users/ckebriti/BASIC_WEBPAGE/helloweb.js:47:15)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.runMain [as _onTimeout] (module.js:497:10)
Process exited with exit code 8
- Tags:
- Intel® Node Manager
I'm not entirely sure but I think there is a dependency on MRAA being installed. Here's the error I received when trying to install.
root@147:~# npm install mraa
> mraa@0.9.3 install /root/node_modules/mraa
> node-gyp rebuild
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
gyp ERR! System Linux 3.14.29ltsi-WR7.0.0.3_standard
gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /root/node_modules/mraa
gyp ERR! node -v v0.10.38
gyp ERR! node-gyp -v v1.0.1
gyp ERR! not ok
npm ERR! mraa@0.9.3 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the mraa@0.9.3 install script.
npm ERR! This is most likely a problem with the mraa package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls mraa
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 3.14.29ltsi-WR7.0.0.3_standard
npm ERR! command "node" "/usr/bin/npm" "install" "mraa"
npm ERR! cwd /root
npm ERR! node -v v0.10.38
npm ERR! npm -v 1.4.28
npm ERR! code ELIFECYCLE
npm ERR! not ok code 0
I'd suggest you to post your question in the Wind river forum https://ask.intel.windriver.com/ https://ask.intel.windriver.com/ . They'll be able to provide a more accurate response.
Sergio
Please note that ask.intel.windriver.com is being discontinued. Anyone with a Wind River support license and login can access their support forum at http://ask.windriver.com/ http://ask.windriver.com . There is also an Intel IoT Gateway Support Community Forum at: /community/tech/iot-gateway https://communities.intel.com/community/tech/iot-gateway
you have no make tool installed:
Need to install it.
BR,
xbolshe
Sorry, I had the wrong output. That was when trying to npm install from user root. I think app.cloud.windriver.com puts some protections in place to avoid the user from installing packages as root. Below is output from when I try to install MRAA.
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ npm install mraa
npm WARN package.json galileo@0.0.0 No repository field.
npm http GET https://registry.npmjs.org/mraa https://registry.npmjs.org/mraa
npm http 304 https://registry.npmjs.org/mraa https://registry.npmjs.org/mraa
> mraa@0.9.6 install /users/ckebriti/BASIC_WEBPAGE/node_modules/mraa
> node-gyp rebuild
Traceback (most recent call last):
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site.py", line 569, in
main()
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site.py", line 551, in main
known_paths = addusersitepackages(known_paths)
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site.py", line 278, in addusersitepackages
user_site = getusersitepackages()
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site.py", line 253, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site.py", line 242, in getuserbase
from sysconfig import get_config_var
File "/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/sysconfig.py", line 10, in
'stdlib': '{base}/'+sys.lib+'/python{py_version_short}',
AttributeError: 'module' object has no attribute 'lib'
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/share/node-gyp/lib/configure.js:431:16)
gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:797:12)
gyp ERR! System Linux 3.13.0-48-generic
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /users/ckebriti/BASIC_WEBPAGE/node_modules/mraa
gyp ERR! node -v v0.10.25
gyp ERR! node-gyp -v v0.10.10
gyp ERR! not ok
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
npm ERR! weird error 1
Try to check the following:
python
>> import sys
>> sys.version
>> sys.path
>> sys.lib
BR,
xbolshe
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ python
Python 2.7.3 (default, Aug 6 2015, 19:46:36)
[GCC 4.9.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> sys.version
'2.7.3 (default, Aug 6 2015, 19:46:36) \n[GCC 4.9.1]'
>>> sys.path
['', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python27.zip', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/plat-linux2', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/lib-tk', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/lib-old', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/lib-dynload', '/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/lib/python2.7/site-packages']
>>> sys.lib
'lib'
Try these commands:
env
export PYTHONHOME=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/
npm install mraa
BR,
xbolshe
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ env
AS=i586-wrs-linux-as
LDFLAGS=-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed
AR=i586-wrs-linux-ar
OECORE_TARGET_SYSROOT=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
TARGET_PREFIX=i586-wrs-linux-
M4=m4
COMP_WORDBREAKS=
SHELL=/bin/bash
TERM=xterm-256color
NM=i586-wrs-linux-nm
OECORE_DISTRO_VERSION=7.0.0.3
CPPFLAGS=
ISOUTPUTPANE=0
LD_PRELOAD=sw_btrace.so
WIND_PROJECT_ROOT=/users/ckebriti/BASIC_WEBPAGE
OECORE_SDK_VERSION=7.0-intel-quark
GDB=i586-wrs-linux-gdb
USER=ckebriti
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:
LD_LIBRARY_PATH=/opt/c9v3/c9sdk/node_modules/clang_tooling/build/lib64:/opt/c9v3/c9sdk/node_modules/clang_tooling/build/lib32:~/.c9/local/lib
PKG_CONFIG_SYSROOT_DIR=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
CXXFLAGS= -O2 -pipe -g
CONFIG_SITE=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/site-config-i586-wrs-linux
COLUMNS=185
TMUX=/tmp/tmux-21502/cloud9_BASIC_WEBPAGE_3515,731,1
CPP=i586-wrs-linux-gcc -E -m32 -march=i586 --sysroot=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
MAIL=/var/mail/ckebriti
PATH=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/bin:/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/bin/i586-wrs-linux:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
WRSD_LICENSE_FILE=27000@172.17.42.1
LD=i586-wrs-linux-ld --sysroot=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
PWD=/users/ckebriti/BASIC_WEBPAGE
STRIP=i586-wrs-linux-strip
NODE_PATH=/opt/c9v3/.c9/node_modules
OECORE_NATIVE_SYSROOT=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux
TMUX_PANE=%1
CONFIGURE_FLAGS=--target=i586-wrs-linux --host=i586-wrs-linux --build=x86_64-linux --with-libtool-sysroot=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
LINES=32
LM_LICENSE_FILE=27000@172.17.42.1
WIND_PROJECT_NAME=BASIC_WEBPAGE
CXX=i586-wrs-linux-g++ -m32 -march=i586 --sysroot=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
OBJCOPY=i586-wrs-linux-objcopy
HOME=/users/ckebriti
SHLVL=4
CFLAGS= -O2 -pipe -g
LOGNAME=ckebriti
PROJECT_ENV_PATH=/users/ckebriti/BASIC_WEBPAGE/.scripts/env.sh
OECORE_ACLOCAL_OPTS=-I /helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/share/aclocal
PKG_CONFIG_PATH=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux/usr/lib/pkgconfig
LESSOPEN=| /usr/bin/lesspipe %s
ARCH=x86
RANLIB=i586-wrs-linux-ranlib
CUSTOM=43
BTRACE_LOG=/users/ckebriti/BASIC_WEBPAGE/.index/btrace.log
CROSS_COMPILE=i586-wrs-linux-
CC=i586-wrs-linux-gcc -m32 -march=i586 --sysroot=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
OBJDUMP=i586-wrs-linux-objdump
LESSCLOSE=/usr/bin/lesspipe %s %s
SDKTARGETSYSROOT=/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/i586-wrs-linux
_=/usr/bin/env
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ export PYTHONHOME=/usr
> node-gyp rebuild
make: Entering directory `/users/ckebriti/BASIC_WEBPAGE/node_modules/mraa/build'
CC(target) Release/obj.target/mraa/src/x86/up.o
cc1: warning: include location "/usr/include/nodejs/src" is unsafe for cross-compilation [-Wpoison-system-directories]
cc1: warning: include location "/usr/include/nodejs/deps/uv/include" is unsafe for cross-compilation [-Wpoison-system-directories]
cc1: warning: include location "/usr/include/nodejs/deps/v8/include" is unsafe for cross-compilation [-Wpoison-system-directories]
../src/x86/up.c:1:0: error: CPU you selected does not support x86-64 instruction set
make: *** [Release/obj.target/mraa/src/x86/up.o] Error 1
make: Leaving directory `/users/ckebriti/BASIC_WEBPAGE/node_modules/mraa/build'
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
gyp ERR! not ok
Extra info:
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ env | grep -i pythonhome
PYTHONHOME=/usr
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ echo $PYTHONHOME
/usr
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ ls /usr
arm-none-eabi bin games include lib lib32 libx32 local sbin share src
ckebriti@helix-app-cloud:~/BASIC_WEBPAGE$ which python
/helixInstall/sdks/wrl7_galileogen2/7.3.0.7/sdk/sysroots/x86_64-wrlinuxsdk-linux/usr/bin/python
Take a look at these two links
- https://github.com/nodejs/node-gyp/issues/809 https://github.com/nodejs/node-gyp/issues/809
- https://github.com/websockets/bufferutil/issues/25 install fails at node-gyp rebuild stage · Issue # 25 · websockets/bufferutil · GitHub
They discuss an error similar to yours, maybe you can find it helpful.
Remember you can also post your question in the Windriver Forum we posted above. They'll be able to provide a more detailed suggestion since they're the ones who support that image.
Sergio
