Community
cancel
Showing results for
Search instead for
Did you mean:
ENovi1
Windows 10 clean install hangs on "Getting files ready..."
Jump to solution
Product Code: BOXSTCK1A32WFCL
s/n: GEFC531008SQ
Had Win 10 on it when purchased. Worked fine until decided to upgrade itself to a newer version of Windows 10 over the air. After that remained bootable but stopped responded on anything after fully loaded on first mouse click, would just hang on any action through the UI, though mouse was remaining movable. Restoration to Win 8.1 from BIOS menu didn't wok - no restore point found. Factory reset didn't work either - problem detected, won't go any further that that. Compiled a new USB flash with Windows 10 with MS MediaCreationTool.exe, attempted fresh install with internal drive fully wiped - no luck, it loads setup which would stop at an arbitrary point from 3% to 95% saying "Getting files ready for installation..." and never progress after. Removing USB media at this point triggers no reaction.
What I tried:
1. Another flash stick
2. Use Win 10 rev.1511 ISO file downloaded from Microsoft with Rufus 2.5 and different Rufus options
3. Re-partition the internal flash drive (actually the install does it automatically - splits the clean single space into 4 partitions, one main and 3 service)
4. Fully re-format the flash stick to make sure it is fully functional
5. Used power stabilizer to make sure no power surge would hurt the power to the stick
One sure observation I made was that the percentage at which it stopped depends on how the installation was supplied to the USB flash drive. It would be 3% for the setup made with MediaCreationTool.exe, 95% for Rufus with "MBR partition scheme for BIOS and UEFI" and 64% with "MBR partition scheme for UEFI" options selected in Rufus.
Ubuntu 14.04.3 LTS installs just fine. From the same stick.
I'm in Ukraine so sending the unit to Intel is not an option. But the stick cannot be "windowized" and it's a problem for me.
JIlmo
Ok I got my win10 working.
Here are the steps which I took, but I don't know if they had anything to do with the success.
- Updated latest bios
- Downloaded drivers from Intel and unzipped them to the win10 installation stick made with the media creation tool.
- Booted via the win10 stick
- Formatted the data partition. I still have the 2 system partitions present.
- Loaded the relevant (and probably several extra) drivers which I unzipped to the usb stick while in the partition selection view.
- Left the stick to install and went to sleep. (important step to cool your nerves)
- When I came back the screen was blank and unresponsive. I booted the stick and it began the welcome process in windows.
- I connected to wlan during the welcome process.
It was smooth sailing from there.
JIlmo
I have the same exact problem.
I've tried multiple different ways to install Win 10 with the same results.
- First upgrade resulted with a windows which hangs on first UI interaction.
- Otherwise it has hung during "getting files ready for installation".
eReig
I had the same issue, though I started with a 8.1 install first that worked perfectly.
Upgraded to windows 10, but desktop froze after a few minutes. F8 option to revert to windows 8.1 was broken and I don`t know if Win 10 upgrade broke it or if it never worked in the first place. Managed to get win 10 activated, so I could do a clean install without serial.
I tried to install windows 10 with several USB sticks, some created by MS mediacreationtool.exe and others via Rufus. Balanced power option in bios, with usb stick, keyboard and mouse connected to a non-powered 4-port USB hub. All resulted in a hang on "Getting files ready". Under a backtracing, I found out that Rufus reverts settings after I load the .ISO image, so I created another USB stick, this time I loaded the .ISO first, then used the GPT partition scheme, fat32 as filesystem and cluster size at default. Install went through without a problem. A bit slow on some portions of "getting files ready", but fast after that.
The freeze issue is most likely caused by write cache on the internal eMMC storage according to another thread here, so I have deactivated that now that I have windows 10 up and running.
PMela1
It seems that this has been a continuous and, so-called, universal problem with the STCK1A32WFCL Sticks. Mine was purchased about a month ago (specifically, on November 26) but after a few unsuccesful trials to install the update 1511 (Windows 10 version 10586), I communicated with Intel, they opened a Support Service Ticket and they advised me to return the Stick and replace it with a new, sealed one.
I followed their advice and when I received the new Stick, the problem was simply repeated and the installation failed again.
So far, I have not been able to install the update 1511, although it is there, waiting to be downloaded and installed. As the previous members have written, I have also tried several alternative ways to install it, but the process freezes in between, usually at about 75% or 77%. However, during my last trial, it freezed at 33%.
Right now, I have downloaded the ISO of the new version, burned on a Dual Layer DVD+R disc, containing both Windows 10 options, the 32-bit one and the 64-bit one. All my previous trials were done, by using, either the classical "download" way, or an external USB stick, on which there was the ISO of the new version. I am thinking to try to install it again, by using an external USB DVD drive and the DVD disc with the ISO file this time, perhaps by doing a clean installation, but again I am not sure if I can do it and I am not sure if it succeeds or fails.
However, before trying, I need an important information: I' ve noticed in the Stick BIOS that in one of its pages there are two options for the Internal UEFI Shell. One is the "Disabled" option and the other is the "Enabled". The default is the "Disabled". Please, observe the following picture:
I am not sure which is the right one, regardless if the default is the "Disabled" option.
Can someone give an advice, which option to use?
Thanks in advance.
eReig
Internal UEFI shell should be disabled.
ENovi1
My device had it disabled and still has
JIlmo
DMoje
Thank you Etikka, really very thanks. I have to thank you for guidance and advice. I had the same problem as at the beginning of this discussion. With your Instructions, I repaired everything. And I did not have to go to sleep, it was pretty fast.
ENovi1
Ettika, you made my day (well it was 3am but...). When I followed your instructions (installing the drivers one by one was a rather tough part but I'd gone through that) it was the first time I passed beyond the "Getting filer ready..." crap. Good job, thanks!
TDěde
Etikka could you please specifi which drivers you install please? I tried your method and still ended on 9% "Getting files ready..."
I downloaded drivers directly from Intell support for Windows 10 32bit support.
thank you
JIlmo
I downloaded the win10 32-bit drivers from https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC
I installed wireless, bluetooth and most of the soc package drivers. It's a bit of a chore installing them one by one, but it doesn't take too long.
GEgil
I had the excact same problem the installer hanging in 17%
Your solution worked perfectly for me ... even though I deleted all the Current partitions from the emmc drive..
I just Updated the bios and I did also install the SOC-drivers (except Audio) and the Wireless driver.
thank you.
Gudm.
TDěde
Well I must say "No luck there"
BIOS "v31" ... checked
Complete wipe of emmc drive ... checked
install drivers during windows clean install ... checked (all SOC, wireless) ... checked
still stuck on 3% or 9% during Getting filles
wbeam
Same here as well. I had one install that actually got to installing updates(from where, I don't know since it couldn't log into my router); but mostly it usually dies out at 6% or 74%.
DMoje
I downloaded and installed drivers from https://downloadcenter.intel.com/product/86612 https://downloadcenter.intel.com/product/86612
list of drivers (win 10 32 bit):
BT_Win10_32_1.0.98.50629.L.zip
GFX_Win8.1_10_32_15.33.39.4276.zip
SOC_BYT_Win10_32.zip
Wireless_Win10_32_3008.11.0515.2015.zip
...but, now is problem with wifi sometimes - turned off wifi - I have to reboot and reconnect. I do not know how to fix it
JIlmo
mojda : I have the same problem. The wifi can't connect after sleep.
You can actually just disable and re-enable the wifi adapter from "view my network connections"-window. That way you don't need to reboot, but it's still a chore.
I ended up adding a USB lan adapter for the time being. I'll have to look into it more when I have time. If nothing else works, you can probably do a script with autohotkey or some other app to automatically disable/re-enable the wifi adapter after wake up.
I suggest you make a new thread for that problem.
wbeam
There's a later version than the one on the Intel site(Intel's is July 4 and the later one is July 30, if I recall correctly), it works much better. I don't have a link, give Google a try.
MG9
Hi Etikka
Could you please check the version of the file setup.exe on the stick you made with the media creation tool.
It contains 10240 or 10586?
JIlmo
Hi mag777
I used the November update, so it was 10586.
MRoba
Mine is hanging at 69% at the getting files ready step...
i did literary everything as you, except that i used Rufus and not the Microsoft tool, for the sole reason that it doesnt create UEFI/GPT media, but things must have changed in the meantime...
I have a question to you regarding the drivers, Windows wont let you go through folders and cherry pick drivers, one is forced to put all the drivers in one folder (literary, all the INF's and stuff extracted on the same place, no folder stuff inside), or else, you'd end up choosing just one driver, as loading the other will remove the first one from the list. Typical Microsoft inconsistency, and they did not include the option to look in the subfolders.
Regarding the driver package, you meant the "SOC_BYT_Win10_32.zip" package right?
PS @all, i like the EFI Shell, and i have it enabled, havent yet tested if things go well without it, but i doubt thats the cause of this...
also, what's with the EMMC Cache, i did not see any option to disable it in the BIOS.
Thanks a lot guys, it seems this is the only place on the internet that is covering exactly this issue.
DBake4
Magic
I had exactly the same issues and did exactly what you did, I updated the BIOS first, added all the unzipped drivers to the boot USB drive and then did a clean install of Windows 10 and it sailed past the stuck at 0% issue and now have a fully working copy of Windows 10.
