Intel® Makers
9867 Discussions
Windows 10 version 1607
FDano
Are we back to a threshold 2 situation again with v 1607? I need 5GB that I don't have. Ideas? Thanks!
n_scott_pearson
Super User Retired Employee
Yes, 1607 installs as an upgrade, not an update, and thus the same situation applies. The answer remains the same: the free space for the upgrade *must* be available on the eMMC.
Here are my suggestions for how to accomplish this:
  1. Remove all of the crap that has built up on your eMMC. To do this, do the following: (1) manually delete all files possible in the C:\Users\XXX\appdata\local\temp folder for each and every user account, (2) manually delete all files possible in the C:\Windows\Temp folder and (3) use the Disk Cleanup tool to remove this and all other crap that has built up. Read this before running the tool: https://support.microsoft.com/en-us/instantanswers/8fef4121-711b-4be1-996f-99e02c7301c2/disk-cleanup... support.microsoft.com: Disk Cleanup in Windows 10. Check to have everything removed (well, except for Game Statistics Files, of course).
  2. Add a SDXC flash IC and migrate applications and data off of the eMMC.
Hope this helps,
Community Manager
N. Scott Pearson, thank you for the information provided.
To: InfoSysLib
Hello InfoSysLib,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back.
I am looking forward to hearing from you.
Angie.
FDano
I forgot to change my iTunes media location to my external drive so when I synched my iPhone it put nearly 2GB of media files on the SSD. That prevented the update, so I removed the files (& the temp windows files) and changed the directory location and the update went smoothly! All is well, thanks!
n_scott_pearson
Glad to hear you found a solution...S
Community Manager
Hello InfoSysLib,
Good to know that your issue has been solved.
Please do not hesitate to use our communities for any further concern.
/news https://communities.intel.com/news
Kind regards,
Angie
