Community
cancel
Showing results for
Search instead for
Did you mean:
MChaw
Windows is over displaying on TV screen. The display does not fit the screen. The resolution is set to 1920 x1080 and scale is set to 100% (recommended). Yet the toolbar and left side are cut off
Hi all
Bought an Intel Compute Stick, but Windows is over displaying. It ti to large for the TV, hence all borders are cut off. The tool bar and the windows assets on the left are just out of view (you can partially see them) . The screen is set to 1920 x1080 and scale set to 100%
Any help will be greatly appreciated
AlHill
Your TV may not support this resolution. You can change the output resolution of the stick, or you can look at the settings of your TV and select another display mode.
You may be able to adjust the underscan (if your stick graphics has that option) to fix this overscan issue. However, I would look at the TV settings first.
Doc
MChaw
Thank you for reply. The TV is a fairly new TV. I have tried all the different resolutions already, and none of them work. On The TV settings, All I can change there are colour, contrast, sharpness and brightness.. I can't see any setting that could resolve this. Thanks
Community Manager
Hello minto007,
I would like to have a better look at this matter, so is there any chance you can take a picture of the toolbar and left side that are cut off? One more thing please let me know your TV model and the Intel® HD Graphics version installed. Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy C.
n_scott_pearson
Super User Retired Employee
Have you tried using the Customize Aspect Ratio feature in the HD Graphics Control Panel?
MChaw
Dear Amy
Thank you for being patient, I have now the information you requested. I have had a new Intel stick delivered, but alas the problem is there with a new one. In answer to your questions
1 - TV Model : I have tried 3 different TVs (all 22 inch - which is detected in the intel graphics software in control panel - Toshiba, Panasonic and ISIS
2- Driver version : 20.19.15.4624 - Which the OS reports as the most up to date and current
3- Picture - See attached - you can see the bottom task bar mostly missing and most of the icons disappearing on the right
Thank you
JVanB
Valued Contributor II
I see this more often than not. There is a setting on the TV to let it know that it's getting a computer signal, not a TV signal, but it's different for each brand of TV. Can you at least specify the brand of TV so that another poster familiar with it can divulge the secret sauce to make this work?
MChaw
Thank you for your reply.. the problem occurs with three different brands , all 22 inch, I have tried. Toshiba, Panasonic and ISIS.. The Intel Graphics software detected these as LCD 22 inch TVs
LeonWaksman
There are different TV models for each company, therefore I advise you to read your TV User Manual and see how the picture can be adjusted. Any way I'll try to give you some hint for the Toshiba TV:
1. Press MENU on Remote Control and enter Picture Settings. Now enter to Advanced Setting and check if Full Mode item is set to 1080iq1060p.
2. Press SCREEN button repeatedly to select different picture format.
3. Use Picture PC Settings menu position to adjust picture position.
Hope this helps
Leon
Community Manager
Minto, were you able to follow the suggestion mentioned before? Did it work?
Amy C.
MChaw
Hi Amy
I'm still having the same problem.. I was waiting for a reply. The driver versions are up to date, and adjusting the TV settings do not work.
regards
Minto
Community Manager
Minto, I would like to confirm if you were able to use the Customize Aspect Ratio feature in the Intel® HD Graphics? This was mentioned before but I couldn't confirm if you tried this.
Amy C.
MChaw
Hi Amy
Sorry if I didn't mention it, but yes, I did use the customise Aspect Ration in the Intel Graphics in Control panel, but to no avail
Cheers
Minto
Community Manager
Did you mean that the option is not present in the Intel® HD Graphics control panel? I am sorry, I got confused and I would like to confirm this.
Thank you.
Amy C.
MChaw
The option is present. I can see it in control panel and use it.. but no matter what options I use it still over displays
Community Manager
Thank you for the clarification.
Can you please access the BIOS and check if the display fits correctly?
Amy C.
Community Manager
Hope you were able to follow the suggestion.
Amy C.
Community Manager
/thread/115462 minto007, if you need further assistance let us know.
Amy C.
MChaw
Thank you all for your replies. Unfortunately I have been unable to do any tests as there appears to be a fault with the power supply adaptor (UK Plug) that was supplied with the Compute Stick, and I'm waiting to get it back. As soon as I have , I'll do the tests above and give you the results
Once again, thank you
Community Manager
Keep us posted.
Amy C.
Community Manager
/thread/115462 minto007, let us know if you were able to test the power adapter.
Amy C.
