Intel® Makers
9882 Discussions
Windows recovery stuck!
DSari1
I bought a new Intel compute stick. It booted fine and started installing all the updates.
Once it updated it rebooted into Windows and immediately froze/crashed. This happened on every boot, leaving no time to even log into the system.
I have tried the recovery process but this always freezes at around 50%.
Does anyone know a way to recover from this?
DSari1
In the end what worked was doing a bios update following the procedure here: http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html Intel® Compute Stick BIOS Recovery Instructions
Then I installed Windows 10 fresh from here: https://www.microsoft.com/en-us/software-download/windows10 Windows 10
This thread helped me the most on this site: /thread/97715 how I got the Compute Stick update to work
Anonymous
Not applicable
Hi sarif,
The new Windows® 10 update requires a BIOS update (latest version if possible)
It is necessary a USB hub, USB 2.0 drive and remove SD card if you have one. Please download the file FC0031.BIO and paste it to the root of the USB drive.
https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]
Turn the stick off, plug the USB drive with .BIO file and keyboard (wire) to hub; plug monitor and hub to stick.
Press and hold the power button down for 3 seconds. Release it before the 4-second shutdown override. Select F4 option.
More details in the link below.
Mike C
