Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Wireless hangs on "Initiating connection to ..."
DSmit48
Edison on mini breakout.
I have run through the setup & flashed the Edison, then run configure_edison --wifi, which works fine, it lists all the available connections (sometimes have to rerun the scan). Once I select my network (I have tried both the 2.4 & 5 Ghz) & enter the password, it just hangs on the initiating stage.
I also tried :
ifconfig usb0 down
ifconfig wlan0 down
ifconfig usb0 up
ifconfig wlan0 up
But same thing. I'm new to the Edison, so any help would be appreciated.
Carlos_M_Intel
Hi Dopeysmith,
Let's try flashing the board using the /docs/DOC-25154 flashall script, then run the configure_edison --setup command.
If the issue continues check the wpa_supplicant.service and disable the connman service by running:
root@edison:~# systemctl status wpa_supplicant.service
root@edison:~# systemctl stop connman
Charlie
Carlos_M_Intel
Hi Dopeysmith,
Charlie
DSmit48
Thanks, I actually re-ran the windows installer again & chose flash image (which I'm guessing did what you suggested), ran configure_edison --setup & it worked. Now I can start playing with the blocks I got for it
Carlos_M_Intel
Hi, I'm really glad to have helped you with this. If in the future you have more questions, doubts or feedback don't hesitate in contacting us
-Charlie
