Community
cancel
Showing results for
Search instead for
Did you mean:
JArne
Wiringx86 - /sys/class/gpio/gpio248/value: No such file or directory
Jump to solution
I try to understand the Edison Brackout Borad.
I am a beginner und go step by step with the book "Getting started with the Intel Eddison an the ...".
And I think I done the follwoing steps succesfully
- update yocto with "iot-devkit-prof-dev-image-edison-20160315"
- initilising python moduls: "wiring-x86" und "pyserial"
But when I start the "Blink Example"
import time
from wiringx86 import GPIOEdison as GPIO
gpio = GPIO(debug=False)
pin = 13
state = gpio.HIGH
print 'Setting up pin %d' % pin
gpio.pinMode(pin, gpio.OUTPUT)
print 'Blinking pin %d now...' % pin
try:
while(True):
gpio.digitalWrite(pin, state)
state = gpio.LOW if state == gpio.HIGH else gpio.HIGH
time.sleep(0.25)
except KeyboardInterrupt:
print '\nCleaning up ...'
gpio.digitalWrite(pin, gpio.LOW)
gpio.cleanup()
Python answers me
sh: /sys/class/gpio/gpio248/value: No such file or directory
sh: /sys/class/gpio/gpio249/value: No such file or directory
sh: /sys/class/gpio/gpio250/value: No such file or directory
sh: /sys/class/gpio/gpio251/value: No such file or directory
sh: /sys/class/gpio/gpio252/value: No such file or directory
sh: /sys/class/gpio/gpio253/value: No such file or directory
sh: /sys/class/gpio/gpio254/value: No such file or directory
sh: /sys/class/gpio/gpio255/value: No such file or directory
sh: /sys/class/gpio/gpio256/value: No such file or directory
sh: /sys/class/gpio/gpio257/value: No such file or directory
sh: /sys/class/gpio/gpio258/value: No such file or directory
sh: /sys/class/gpio/gpio240/value: No such file or directory
sh: /sys/class/gpio/gpio263/value: No such file or directory
sh: /sys/class/gpio/gpio259/value: No such file or directory
sh: /sys/class/gpio/gpio241/value: No such file or directory
sh: /sys/class/gpio/gpio262/value: No such file or directory
sh: /sys/class/gpio/gpio260/value: No such file or directory
sh: /sys/class/gpio/gpio242/value: No such file or directory
sh: /sys/class/gpio/gpio261/value: No such file or directory
sh: /sys/class/gpio/gpio243/value: No such file or directory
sh: /sys/class/gpio/gpio232/value: No such file or directory
sh: /sys/class/gpio/gpio200/value: No such file or directory
sh: /sys/class/gpio/gpio233/value: No such file or directory
sh: /sys/class/gpio/gpio201/value: No such file or directory
sh: /sys/class/gpio/gpio234/value: No such file or directory
sh: /sys/class/gpio/gpio202/value: No such file or directory
sh: /sys/class/gpio/gpio235/value: No such file or directory
sh: /sys/class/gpio/gpio203/value: No such file or directory
sh: /sys/class/gpio/gpio236/value: No such file or directory
sh: /sys/class/gpio/gpio204/value: No such file or directory
sh: /sys/class/gpio/gpio237/value: No such file or directory
sh: /sys/class/gpio/gpio205/value: No such file or directory
Setting up pin 13
sh: /sys/class/gpio/gpio229/value: No such file or directory
Blinking pin 13 now...
Can anyone tell me my mistake?
Jens
Community Manager
Hi Arnert,
If you are new with the Intel Edison board, I suggest you to follow this guide: https://software.intel.com/en-us/get-started-edison-windows, it has a lot of information that can be helpful.
About your issue it looks like a problem with Wiring-x86, I personally recommend you to use the MRAA library that is normally use for the GPIOs of the Intel Edison and Galileo boards. Take a look at this thread: https://communities.intel.com/thread/92493 https://communities.intel.com/thread/92493 (Just ignore that it is about Galileo, just read the information about MRAA), I think that the MRAA library is better because it has support for a lot more interfaces than Wiring-x86.
To use the latest version of MRAA use this repository: http://iotdk.intel.com/repos/3.5/intelgalactic/opkg/i586/, use it instead of http://iotdk.intel.com/repos/2.0/intelgalactic if you follow the steps of the thread.
I hope you find this information useful,
-Leonardo
Community Manager
Hi Arnert,
-Leonardo
Community Manager
Hi Arnert,
Was the information helpful? Did you successfully use the GPIOs with MRAA library?
-Leonardo
