Community
cancel
Showing results for
Search instead for
Did you mean:
CChri35
New Contributor II
Write save filesystem
Hi!
I'm running a c++ program on my edison. Sometimes, if I remove the DC power, and the program
that was running, has 0 bytes afterwards (and therefore isn't able to restart). How can I save the binaries
that I'm running?
Thx!
Community Manager
Hi Christoph,
Thank you very much for contacting us. Let us try to assist you.
I would like to have some more information about your issue if that is possible. So after compilation, no binary files are created, right? Therefore you're not able to run the program on Edison after running it once. Please let me know if I'm not getting something.
I believe there's a similar thread about this that you can read and see if this is the same issue you're getting, /thread/100606 https://communities.intel.com/thread/100606. Let me know if it helps you.
-Pablo
Community Manager
Hi Christoph,
I hope you're doing fine. I'm just wondering if you check our first reply last time, if so, could you please provide the information we requested? Also, did you check the thread we suggested?
-Pablo
