Intel® Makers
9868 Discussions
XDK IoT edition doesn't recognize Galileo's board
TLima2
I'm trying to connect my Galileo's board to the internet to send commands and receive sensor's data. First, I want to create a basic connection, then, utilize MQTT Protocol to send and recive data.For this, I am using this book: Intel Galileo Blueprints - Marco Schwartz. In Chapter 4, the author says to install XDK IoT version and install a linux iso on a micro SD. I followed this tutorial: https://software.intel.com/fr-fr/programming-blank-sd-card-with-yocto-linux-image-windows https://software.intel.com/fr-fr/programming-blank-sd-card-with-yocto-linux-image-windows, then: https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows# terminal https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows# terminal and finally: https://software.intel.com/en-us/getting-started-with-the-intel-xdk-iot-edition https://software.intel.com/en-us/getting-started-with-the-intel-xdk-iot-edition, including installing all the softwares required. However, when I connect the Galileo's board with an ethernet cable, as the micro SD with Linux Iso, XDK doesn't recognize it. I tried automatic search, and doesn't recognize it, tried to enter the IP address manually, and doesn't recognized it. I Would like to know what is going on, why can't recognize.
Carlos_M_Intel
Hi TarcisioLima,
Did you update the firmware of the board by following this guide: http://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf Firmware Updater User Guide
Are you sure that you have access to Internet, are you able to ping google?
Have you tried with ifconfig lo down?
Which XDK version are you using?
What is the output of running opkg list-installed xdk-daemon?
Could you attach a screenshot of the error you are receiving in the XDK?
Charlie
Carlos_M_Intel
Hi TarcisioLima,
Do you have updates on this?
Have you tried with the suggestions above?
Charlie
