Intel® Makers
9880 Discussions
XDK IoT edition fails to connect to Joule running Ubuntu 16.04.1
wwelc1
New Contributor II
I have installed Ubuntu 16.04.1 classic on my Joule and set up SSH connection as follows;
1. sudo vi /etc/ssh/sshd_config
added a line "PermitRootLongin yes"
2. sudo passwd
set the root password
3. sudo iptables -F
4. sudo iptables -P INPUT ACCEPT
5. sudo iptables -P FORWARD ACCEPT
6. sudo iptables -P OUTPUT ACCEPT
7. sudo iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
Then I confirmed that I can SSH login to Joule from Mac;
ssh sorrow@192.168.xxx.xxx
However, when I try to connect to my Joule from XDK IoT Edition on the same Mac, it gives me an error;
Error forwarding port
Error: (SSH) Channel open failure: Connection refused
I tried ssh sorrow@192.168.xxx.xxx -p 58888 and this gives me the same Conncetion refused error. It appears to be a problem of port forwarding, but sudo iptables -S gives me -P FORWARD ACCEPT.
The XDK IoT Edition is updated to 3641. It is not likely to be a problem of the rooter, since I could connect to the same Joule with Ostro XT from a PC.
Any suggestion would be most welcome.
sorrow
wwelc1
New Contributor II
Hi Pablo,
I came to realize that "xdk-daemon" has to be installed and running on the target device to be accessed from XDK. And I found an answere here;
https://software.intel.com/en-us/xdk/faqs/iot# linux-distributions Intel® XDK FAQs - IoT | Intel® Software
Can the xdk-daemon run on other Linux distributions besides Yocto?
The Intel XDK xdk-daemon is currently (November, 2016) only supported on the Yocto and Ostro Linux distributions. Work is ongoing to provide a version of the xdk-daemon that will run on a wider range of IoT Linux platforms.
It appears that xdk-daemon setups port forwarding from tcp input to 58888. I hope they do it first for Ubuntu. Until then I will have to wait or use another IDE.
cheers,
sorrow
Community Manager
Hi Sorrow,
Thank you for reaching out. I would like to let you know that for all Ubuntu questions on Joule, you should contact the Ubuntu Support. Here's the link https://developer.ubuntu.com/en/snappy/start/intel-joule/ https://developer.ubuntu.com/en/snappy/start/intel-joule/. Please keep in mind that this product is still in beta.
-Pablo
wwelc1
New Contributor II
Thanks Pablo,
I posted the question to askubuntu.com.
http://askubuntu.com/questions/853700/ssh-connection-error-of-intel-joule-running-ubuntu-16-04-1-lts SSH connection error of Intel Joule running Ubuntu 16.04.1 LTS
sorrow
wwelc1
New Contributor II
Hi Pablo,
cheers,
sorrow
