I got an Intel Galileo Gen 2 and the XDK does not automatically find the Galileo, but I can add it manualy.
Is it possible to get it to be found automatically?
Hi Kim,
If you the device is not automatically detected you can try with:
Your IoT device must be on the same subnet network.
Windows: Please make sure Bonjour is installed. ( click here for instructions )
Linux: Please make sure avahi-browser or libavahi-compat-libdnssd1 has been installed.
If this doesn't work either, you will have to continue adding the device manually.
Charlie
Your "click here" links does not work.
The XDK finds the Intel Edison. Sow must be somthing with the Galileo, also the galileo local host name does not work. (on my edison its called, edison.local)
Hi Kim,
I was trying to showing you the information on:
Are you using galileo.local in the XDK to connect the board? You need to use the IP address in order to connect the board to the XDK IDE.
Which XDK version, xdk-daemon and image are you using?
Charlie
Hi Kim,
You need to use the IP address of the board while using the XDK.
Also, do you have Bonjour installed on your PC? Also check the subnet network of the device and the PC.
Charlie
