Intel® Makers
9880 Discussions
XDK v3759 met by permission errors upon project upload to Joule
wwelc1
New Contributor II
I have a problem uploading projects to Joule, where Joule gives permission errors for opeing tar archived files of the project. My Joule is running Ubuntu 16.04.1 LTS, XDK v3759, and xdk-daemon. The project is Intel's sample code Bluemix Quick Start.
Do I need to chown the directory to which files are uploaded?
Thanks for your help.
wwelc1
New Contributor II
I am now connecting to Joule as root and permission errors are gone. However, nothing is uploaded to /node_app_slot, i.e. a symlink to /home/root/.node_app_slot.
This is what I get:
Upload Complete
There does not appear to be a project/package.json in /node_app_slot/
Attempting to run anyway . . .
ERROR: Unable to start application! (try re-uploading a project from the Intel XDK.)
Any suggestion?
Community Manager
Hi welcomesorrow,
Thanks for your interest in the Intel Joule Platform.
The Intel XDK has only been tested with the Joule using the Ostro image. Nevertheless I encourage you to contact the Ubuntu community and ask if anybody has an issue similar to yours (https://developer.ubuntu.com/en/snappy/start/intel-joule/ Intel Joule | Ubuntu developer portal ).
Also I leave this link if you decide to use Ostro: (https://software.intel.com/en-us/node/643667 IoT - Programming your development platform with Node.js*: Intel® XDK | Intel® Software ).
I hope you find this information useful, have a nice day!
-Jose.
wwelc1
New Contributor II
Hi jose,
Thanks for your comments. I have been looking into the xdk-daemon setup scripts and have a few basic questions.
1. /opt/xdk-daemon/xdk-daemon
xdk-daemon is installed in the /opt/xdk-daemon folder. This is a part of the xdk-daemon script:
APPSLOT="/node_app_slot"
/bin/mkdir -p /home/root/.node_app_slot
if [ -h "$APPSLOT" ]
then
echo "$APPSLOT exists and is a symbolic link."
elif [ -d "$APPSLOT" ]
then
echo "$APPSLOT is a directory (old format... updating)"
/bin/cp -ar $APPSLOT/* /home/root/.node_app_slot
rm -rf $APPSLOT
/bin/ln -s /home/root/.node_app_slot $APPSLOT
else
echo "Creating symbolic link to $APPSLOT"
fi
My question is why does it "mkdir" /home/root/.node_app_slot which can not be accessed from a normal user? This is the cause of all troubles. I am curious how Ostro XT avoids this obvious permission error. It seems to make more sense if it "mkdir" /home/$USER/.node_app_slot which is accessible from the user.
2. /opt/xdk-daemon/setup.sh
There are syntax errors in this setup script:
echo " Installing modules for daemon version manager"
echo "--------------------------------------------------------------------"
$SUDO cd $DIR
$SUDO export CPLUS_INCLUDE_PATH=/usr/include/avahi-compat-libdns_sd
$SUDO npm install
echo " DONE!"
You can not "sudo cd". It will give you an error unless $SUDO is empty. Same for export. Perhaps you can do it as follows;
$SUDO sh -c "cd $DIR;
export CPLUS_INCLUDE_PATH=/usr/include/avahi-compat-libdns_sd; npm install"
Community Manager
Hi welcomesorrow,
In the Ostro image you can access the .node_app_slot without any permision. See image below.
I would encourage you to contact the Ubuntu community and ask why this restrictions exists.
Hope you find this information useful, have a nice day!
-Jose.
wwelc1
New Contributor II
Hi Jose,
Thank you for your information and suggestions. It means that Ostro XT runs XDK with a root previledge. It also explains why "$SUDO cd $DIR" in /opt/xdk-daemon/setup.sh script should not give any error ($SUDO will be a blank if 'whoami' == "root").
Now, my question to the XDK development team would be if one can modify the target directory from /home/root/.node_app_slot to /home/$USER/.node_app_slot (/opt/xdk-daemon/xdk-daemon). In Ubuntu 16.04.1, 'whoami' is usually not root.
wwelc1
New Contributor II
I have now solved the issue by starting XDK as root;
cd /opt/intel/XDK
gksudo ./xdk.sh
One thing that has to be done is to remove $SUDO from five lines in /opt/xdk-daemon/setup.sh file which cause command not found errors. To do so, first stop xdk-daemon and then edit the setup.sh;
systemctl stop xdk-daemon
sudo rm -rf /opt/xdk-daemon
cd ~/xdk-daemon-0100-x64-node-4.5.0
nano setup.sh
Remove $SUDO from all the following lines;
$SUDO cd $DIR
$SUDO exort CPLUS_INCLUDE_PATH=/usr/include/avahi-compat-libdns_sd
$SUDO cd $DIR/current
$SUDO cd $DIR/current/node-inspector-server
$SUDO cd $DIR
Install a dependency library before running the setup.sh script again.
sudo apt-get install libavahi-compat-libdnssd-dev
./setup.sh
That will allow installation of mdns, bindings, and nan node modules in /opt/xdk-daemon/current folder.
Answere yes to the question at the end of the process, or otherwise mannualy start the daemon by
systemctl start xdk-daemon
An alternative approach to avoid permission errors upon writing to node_app_slot is to
mkdir home/$USER/.node_app_slot
sudo rm -rf /node_app_slot
sudo ln -s /home/$USER/.node_app_slot /node_app_slot
and run xdk as normal,
cd /opt/intel/XDK
./xdk.sh
Community Manager
Hi welcomesorrow,
I'm glad hear that you solved your issue!
Many thanks for sharing your results in such a detail manner! We appreciate your contribution since it might benefit other users.
If you have any more questions, please don't hesitate to ask.
Have a nice weekend!
-Jose.
