Intel® Makers
9882 Discussions
Yaafe installation
AMont11
Hi all,
I have gotten yaafe to install on the edison, but I am having trouble installing it on the board, Has anyone got this to work?
If so please help !
AMont11
This is my log output :
root@edison:~/yaafe-v0.64# cmake -DCMAKE_INSTALL_PREFIX:PATH=/usr/bin/
-- Found Argtable2: /usr/local/lib/libargtable2.so
-- Found dl: /usr/lib/libdl.so
-- Found libsndfile: /usr/local/lib/libsndfile.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/root/yaafe-v0.64
root@edison:~/yaafe-v0.64# make
Scanning dependencies of target audio-smarc
[ 1%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/polyfilt.c.o
[ 2%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/smarc.c.o
[ 4%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/multi_stage.c.o
[ 5%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/stage_impl.c.o
[ 7%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/remez_lp.c.o
[ 8%] Building C object externals/CMakeFiles/audio-smarc.dir/audio-smarc/filtering.c.o
Linking C static library libaudio-smarc.a
[ 8%] Built target audio-smarc
Scanning dependencies of target yaafe-core
[ 10%] Building CXX object src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/ComponentPool.cpp.o
[ 11%] Building CXX object src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/AudioFileProcessor.cpp.o
In file included from /home/root/yaafe-v0.64/src_cpp/yaafe-core/DirectedGraph.h:31:0,
from /home/root/yaafe-v0.64/src_cpp/yaafe-core/DataFlow.h:28,
from /home/root/yaafe-v0.64/src_cpp/yaafe-core/AudioFileProcessor.h:28,
from /home/root/yaafe-v0.64/src_cpp/yaafe-core/AudioFileProcessor.cpp:25:
/home/root/yaafe-v0.64/src_cpp/yaafe-core/Ports.h: In instantiation of 'void YAAFE::Ports::add(const T&) [with T = YAAFE::StreamInfo]':
/home/root/yaafe-v0.64/src_cpp/yaafe-core/AudioFileProcessor.cpp:139:45: required from here
/home/root/yaafe-v0.64/src_cpp/yaafe-core/Ports.h:62:27: error: 'push_back' was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
push_back(Port("",val));
/home/root/yaafe-v0.64/src_cpp/yaafe-core/Ports.h:62:27: note: declarations in dependent base 'std::vector, std::allocator > >' are not found by unqualified lookup
/home/root/yaafe-v0.64/src_cpp/yaafe-core/Ports.h:62:27: note: use 'this->push_back' instead
src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/build.make:77: recipe for target 'src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/AudioFileProcessor.cpp.o' failed
make[2]: *** [src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/AudioFileProcessor.cpp.o] Error 1
CMakeFiles/Makefile2:186: recipe for target 'src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/all' failed
make[1]: *** [src_cpp/yaafe-core/CMakeFiles/yaafe-core.dir/all] Error 2
Makefile:133: recipe for target 'all' failed
make: *** [all] Error 2
Pedro_M_Intel
Hello a_Monteiro,
To install yaafe, you need to use the command ccmake, which Edison does not include, so you will probably have to build a newer version of https://cmake.org/download/ CMake from source.
Also, did you make sure to install all the dependencies needed for yaafe? Take a look at http://yaafe.sourceforge.net/manual/install.html 1. Installing Yaafe — YAAFE - Yet Another Audio Feature Extractor, there you can find all the dependencies you will need and the instructions to install it once you have everything that's needed.
Peter.
